Calculate the limit cos(x)/sin(x) when x approaches 0
  • Thread starter Thread starter Lambda96
    Cos Limit Sin
Lambda96
Calculate ##\displaystyle{\lim_{x \to 0}} \frac{\cos(x)}{\sin(x)}##
none
Hi,
I need to check whether the limit of the following function exists or not
I have now proceeded as follows to look at the right-sided and left-sided limit i.e. ##\displaystyle{\lim_{x \to 0^{+}}}## and ##\displaystyle{\lim_{x \to 0^{-}}}##
To do this, I drew up a list in which I move from 1 closer and closer to 0 and for the left-hand side from -1 towards 0 and got the following:
As you can see, the function tends from the right towards ##\infty## and from the left towards ##- \infty## As the two values are therefore not equal, the function has no limit at the point ##x=0##
My question, can I prove it this way, or is there a way to prove it more precisely mathematically?
Lambda96 said:
Homework Statement: Calculate ##\displaystyle{\lim_{x \to 0}} \frac{\cos(x)}{\sin(x)}##
Relevant Equations: none
Hi,
View attachment 338389I have now proceeded as follows to look at the right-sided and left-sided limit i.e. ##\displaystyle{\lim_{x \to 0^{+}}}## and ##\displaystyle{\lim_{x \to 0^{-}}}##
If you're asked to prove that the limit exists or doesn't exist, calculating a table of values doesn't do the job. What you would need to do in this case is a sort of modified ##\delta - \epsilon## argument. In this case you would need to show that for any given (large number) M, there is a (small number) ##\delta > 0## such that whenever ##|x - 0| < \delta##, where ##x \ne 0##, then ##|\frac{\cos(x)}{\sin(x)}| > M##. As a side note, ##\frac{\cos(x)}{\sin(x)}= = \cot(x)##.
Likes MatinSAR and Lambda96
Still, it seems you're working on the extended Reals, if ##\mathbb R## with the line on top *. Edit: Then the limit of infinity could exist.
*Sorry, don't know how to Latex it in.
WWGD said:
Still, it seems you're working on the extended Reals, if ##\mathbb R## with the line on top *. Then the limit exists and it's infinity.
##\overline{\mathbb R}##
Likes MatinSAR, Lambda96 and WWGD
That is true for the projectively extended reals. The normal extended reals have two infinities and no limit here.
Yes, not this expression, but either of ## \infty, -\infty ## are possible limits in
##\overline {\mathbb R}##
Thank you Mark44, WWGD, Orodruin and Office_Shredder for your help
I have now proceeded as Mark44 described:
The following applies ##|x-0|< \delta \rightarrow x < \delta## and ##\frac{\cos(x)}{\sin(x)}>M \rightarrow \cot(x)>M##
Then I calculated the following
##\cot(x) > M \qquad | \text{Form reciprocal value}##
##\frac{1}{\cot(x)} < \frac{1}{M} \qquad |\frac{1}{\cot(x)}= \tan(x)##
##\tan(x) < \frac{1}{M} \qquad | \arctan(...)##
##x < \arctan(\frac{1}{M})##
It then follows that for ##\cot(x) > M##, ##\delta## must be chosen as follows ##\delta = \arctan(\frac{1}{M})##
You can use Taylor series ...
##cos(x)=1-\frac{x^2}{2!}+\frac{x^4}{4!}-\frac{x^6}{6!}+\frac{x^8}{8!}-...##
##sin(x)=x-\frac{x^3}{3!}+\frac{x^5}{5!}-\frac{x^7}{7!}+\frac{x^9}{9!}-...##
... and approximate with first members of two series ...
(the same as replacing functions cos(x) and sin(x) with their tangent straight lines for x=0)
=\displaystyle{\lim_{x \to 0}} \frac{1}{x}##
From the left side ##x \to -0## you can get
##\displaystyle{\lim_{x \to -0}} \frac{1}{x}
=\displaystyle{\lim_{x \to -\infty}} \frac{1}{ \frac{1}{x}}
=\displaystyle{\lim_{x \to -\infty}} x =-\infty##
Also from the right side ##x \to +0## you can get
##\displaystyle{\lim_{x \to +0}} \frac{1}{x}
=\displaystyle{\lim_{x \to +\infty}} \frac{1}{ \frac{1}{x}}
=\displaystyle{\lim_{x \to +\infty}} x =+\infty##
Cotangent function is ##ctg(x)=cot(x)=\frac{\cos(x)}{\sin(x)}##
Wolfram alpha -> https://www.wolframalpha.com/input?i=cos(x)/sin(x)
Likes Lambda96 and WWGD
You can see that \cos x/\sin x is odd, so either the limit is zero or the limit does not exist. The limit is not zero: since \tan x \to 0, for each R &gt; 0 there exists \delta &gt; 0 such that if 0 &lt; |x| &lt; \delta then |\tan x| &lt; R^{-1} and |\cot x| &gt; R.
Likes Lambda96, MatinSAR and PeroK
I'm not convinced you need an epsilon-delta proof, as long as you can use basic properties of sine and cosine.
$$\lim_{x \to 0} \cos x =1$$$$\lim_{x \to 0}\sin x = 0$$$$0 < x < \pi \ \Rightarrow \ \sin x > 0$$$$-\pi <x<0 \ \Rightarrow \ \sin x < 0$$
Likes Lambda96, MatinSAR and nuuskur
This is correct. You have shown the limit does not exist.
In the topology of the Extended Reals, the limit as ##\infty## may exist if your expression grows without bound in the positive direction, i.e., it would be in the neighborhood ##(a, \infty]; a>0##. Similar for ##-\infty ## as a limit. That's not the case here, as cotan alternates signs.
https://en.m.wikipedia.org/wiki/Extended_real_number_line
Thank you Bosko, pasmith, PeroK, nuuskur and WWGD for your help 👍👍👍👍👍
Thanks PeroK with the tip to argue that the sine around ##x=0## is asymmetric and therefore the limit ##\displaystyle{\lim_{x \to 0^-}} \frac{\cos(x)}{\sin(x)}=- \infty## and ##\displaystyle{\lim_{x \to 0^+}} \frac{\cos(x)}{\sin(x)}= \infty## and therefore the limit ##\displaystyle{\lim_{x \to 0}} \frac{\cos(x)}{\sin(x)}## does not exist
Likes nuuskur, WWGD and SammyS
