Calculate the magnitude of the charge on each sphere
In summary, two identical small spheres of mass 2.0g are suspended by a thread and given identical electric charges. The magnitude of the charge on each sphere can be calculated by considering the three forces acting on the spheres and resolving the tension in the x and y directions. By applying Coulomb's Law and using trigonometry, the magnitude of the charge and the distance between the spheres can be determined.
Bradsteeves
Two identical small spheres of mass 2.0g are fastened to the ends of an insulating thread of length 0.60m. The spheres are suspended by a hook in the ceiling from the centre of the thread. The spheres are given identical electric and hang in static equillibrium, with an angle of 30 degrees between the string halves. Calculate the magnitude of the charge on each sphere.
Basically looks like a triangle with the top corner angle 30 degrees, and both sides 0.3m each with the bottom side unknown which is r.
-Consider the 3 forces acting on the sphere
-Resolve the tension in the x and y directions
-Find FE
-Find r
-Apply Coulomb's Law
Given: m = 0.002 kg
r = ?
theta = 30 degrees
s1 = 0.3m
s2 = 0.3m
q = ?
FE = ?
Sin (theta) = Opp/Hyp
Cos(theta)= Adj/Hyp
Sum of all forces in the x and y directions = ma
FE = kq1q2/r^2
Sin theta = Opp/Hyp
0 = sin(theta) X Hyp
= sin 15 X .3m
=0.0776 X 2
= 1.55m
Fe = Kq1q2/r^2
Thats how far I got, I know I am supposed to find the force of tension some how but not sure
Hi Bradsteeves,
Bradsteeves said:
Sin theta = Opp/Hyp
= sin 15 X .3m
=0.0776 X 2
= 1.55m
I think you have the decimal in the wrong place here; it should be r=0.155 meters.
You can find the tension by looking at the forces in the vertical (y) direction. You know gravity is pulling down (the weight), and you can write the component of the tension that's pulling up. Since it's in equilibrium, these have to cancel. What do you get for the tension?
i got 0.0196 for the tension?
The weight is equal to 0.0196. And so that is equal to the vertical component of tension:
[tex]
T_y = m g
[/tex]
But what is [tex]T_y[/tex]? It will be T times a trig function; once you figure out the trig function you can plug it into the above equation and solve for T (since you already know the angle is 15 degrees).
FAQ: Calculate the magnitude of the charge on each sphere
What is the formula for calculating the magnitude of charge on each sphere?
The formula for calculating the magnitude of charge on each sphere is Q = kQ1Q2/r^2, where Q is the magnitude of charge, k is the Coulomb's constant, Q1 and Q2 are the charges on the two spheres, and r is the distance between them.
How do I determine the distance between the two spheres?
The distance between the two spheres can be determined by measuring the distance between their centers using a ruler or by using the Pythagorean theorem if the spheres are not directly aligned.
What is the unit of measurement for the magnitude of charge?
The unit of measurement for the magnitude of charge is Coulomb (C). It is a unit of electric charge named after the French physicist Charles-Augustin de Coulomb.
Can the magnitude of charge on each sphere be negative?
Yes, the magnitude of charge on each sphere can be negative. This indicates that the spheres have opposite charges, with one being positively charged and the other being negatively charged.
How do I interpret the magnitude of charge on each sphere?
The magnitude of charge on each sphere represents the strength of the electric force between them. The greater the magnitude of charge, the stronger the repulsive or attractive force between the spheres will be.
