Calculate the maximum power of the resistor in a circuit
In summary, the equivalent resistance of the left side is ##Z = R_g + jωL_g = 50(1+j\sqrt3)##.For the part b)The answer is ##R_p = \left | Z \right |## = 100.For the part c)The average power ##P_p=R_p* \frac{E^2}{(|Z + R_p|)^2} = 100*\frac{36}{(150+j50\sqrt3)^2}=120[mW]##.For the part a) I don't know what all available means but i supposed it's the
diredragon
323
In an AC circuit of periodic current we know: ##E=6[V]##, ##R_g=50[Ω]##, ##L_g=\sqrt3 [nH]## and ##ω=50*10^9[s^{-1}]##. Calculate:
a) All available power of the ##E##
b) The resistance of ##R## so that the average power is max
c) That average power from part b)
3. The Attempt at a Solution [/B]
First the equivalent resistance of the left side is
For the part b)
My question is since we are looking for ##P_p = R_pI^2##, the active power, shouldn't ##R_p## equal the real part of Z and not it's effective value? If not, in which case is that the solution since I've seen a couple of problems having that solution. I am not sure if they had ##R_p## or some ##Z_p## on the right.
The book gives the answer ##R_p = \left | Z \right |## = 100.
For the part c)
In this case the average power ##P_p=R_p* \frac{E^2}{(|Z + R_p|)^2} = 100*\frac{36}{(150+j50\sqrt3)^2}=120[mW]##
For the part a)
I don't know what all available means but i supposed it's the power of the generator as it is in this resistance but it's not.
The solution for c) is ##\frac{E^2}{4R_g} = 180 [mW]##. How to get this?
The current is the same theough all elements, since they are all in series.
diredragon said:
My question is since we are looking for Pp=RpI2Pp=RpI2P_p = R_pI^2, the active power, shouldn't RpRpR_p equal the real part of Z and not it's effective value?
Try both loads and determine which has the higher load power. Or, you could set yourself a numerical exercise to test this. Picture a source with impedance Z=1+j1. Is there more power in the load if resistance of load is 1Ω or √2Ω? Calculate for both cases.
Likes diredragon and scottdave
You need to consider the entire Z, to know how much current is passing through the resisitor. As @diredragon said, try different values. If you have a way to plot this, then plot over a range of values.
Likes diredragon
Also, the resistor doesn't "care" what the phase of the current running through it is. The voltage across a resistor will be in phase with the current passing through it, so you can just multiply the (magnitude of the current)2 by the resistance, to get the power for that resistor.
As for Average Power, think of it as the power generated by the portion of current which is in-phase with the voltage. So if you look at the entire circuit, then just look at the real portion of the current delivered, that will be the amount which is in phase with the source voltage.
For these types of problems, a calculator, which handles complex numbers, really saves the day. If you don't have that, then perhaps you have access to MATLAB or Maple. I suppose Wolframalpha could do the work, too. Another thing to look at: Python (a programming language) can handle complex numbers. It might be worth a look, since it is free.
I agree with scottdave it would be better if you could use a program handling complex numbers-in my opinion even Microsoft Excel (from 2010 edition) would do the job. However it is still not so complicate if you will insert all the resistance in the circuit in order to calculate the current. And then the power dissipated in circuit will be P=(Rg+Rp)*I^2. Now you have to put d(P)/d(Rp)=0. The result will be Rp=2*w*Lg-Rg I think for the maximum power.
If R in b) it is Rp then P(Rp)=Rp*E^2/((Rg+Rp)^2+Xg^2) and from dP/dRp=0 (for maximum) you'll get Rp=sqrt(Rg^2+Xg^2) =100 ohm indeed.
Now "the average power" in this circuit has to be total losses in Rp and Rg and then the result is 0.18 W indeed.
The complication is not in the calculation just in the logic.
Likes diredragon
Thanks for the replies. I do get it now :)
Likes scottdave
Related to Calculate the maximum power of the resistor in a circuit
What is the maximum power of a resistor?
The maximum power of a resistor refers to the highest amount of energy that can be dissipated by the resistor without causing damage or failure. It is typically represented in watts (W) and is determined by the voltage and current in the circuit.
How do you calculate the maximum power of a resistor?
The maximum power of a resistor can be calculated using the formula P = V^2/R, where P is the power in watts, V is the voltage in volts, and R is the resistance in ohms. Alternatively, it can also be calculated using P = I^2 x R, where I is the current in amperes.
Why is it important to know the maximum power of a resistor?
Knowing the maximum power of a resistor is important because it helps ensure that the resistor can handle the amount of energy being dissipated in the circuit. If the power exceeds the maximum, the resistor may overheat and fail, potentially causing damage to the entire circuit.
What factors can affect the maximum power of a resistor?
The maximum power of a resistor can be affected by several factors, including the material and size of the resistor, the ambient temperature, and the voltage and current in the circuit. Higher voltage and current levels, as well as higher temperatures, can decrease the maximum power of a resistor.
How can the maximum power of a resistor be increased?
The maximum power of a resistor can be increased by using a larger resistor with a higher power rating, or by connecting multiple resistors in parallel to share the power load. Additionally, keeping the ambient temperature low and reducing the voltage and current in the circuit can also increase the maximum power of the resistor.
