Calculate the molarity of Br2 in the stock solution.
  • Thread starter mousesgr
  • Tags
    Molarity
In summary, the molarity of bromine in the stock solution is 1.93 mol/L. This can be calculated by dividing the amount of bromine (232.5 g) by its molar mass (159.808 g/mol), then dividing by the volume of the solution (0.75 L). The presence of KBr in the solution may affect the equilibrium of the dissolution reaction, but its contribution to the molarity of bromine can be neglected in this calculation.
mousesgr
31
The stock solution of bromine is prepared by dissolving 232.5 g of Br2 and 187.5 g of KBr in water and diluting to 750 ml. Calculate the molarity of Br2 in the stock solution.
how to do this qs?
Chemistry news on Phys.org
What's the definition of molarity...?Theory must be known b4 attempting to solve exercises...
Daniel.
Daniel.
no. of mole / volume?
PER LITER OF SOLLUTION...:wink: Now compute it...
Daniel.
From http://www.webelements.com/webelements/elements/text/Br/key.html
I took the mass of Br. Since you have [itex]\mbox{Br}_{2}[/itex],
one 1mol of [itex]\mbox{Br}_{2}[/itex] weighs 2* 79.904g
Divide 232.5 g by (2* 79.904g) , which equals 1.45487.
So you got 1.45mol of [itex]\mbox{Br}_{2}[/itex].
Now you need the molarity which is the concentration:
[itex] c= \frac{1.45mol}{0.75l} = 1.93 \frac{mol}{l} [/itex]
I hope this is right.
I don't know what role the KBr plays, I guess that it helps
dilluting the [itex]Br_{2}[/itex]. Note that I didn't take into account
the KBr.
Even if this is not posted in the HM section,still solving the problem instead of the OP is not reccomendable.So take this as an advice for future "urges"...:wink:
Daniel.
I think there still may be a mistake in my solution.
The fact that they give the information "187.5 g KBr" makes me a little
bit doubtful.
If you have to take the KBr into account, then I hope you know
how to solve it mousesgr.
That "Br2" (or [itex]Br_{2} [/itex]) is surely misleading.It may still refer only to bromine MOLECULES...But if u read it simply as "bromine" (as in "molarity of bromine"),then,of course,u have to include the bromine from the bromide.
Danie.
how to do this qs?
I've been trying to not answer this because it's not clear what the level of the poster is. At the simplest level, you just do the calculation performed by edgardo.
At a higher level of sophistication, you need to consider what happens when you dissolve Bromine in water...about the same that happens with chlorine :
[tex]Br_2 + H_2O \leftrightharpoons HBr + HOBr [/itex] But it's important to note that the products will be present in aqueous solution, in their ionic forms, [itex]H^+,~Br^-,~Br^+,~OH^- [/itex]. The amounts of molecular and ionic bromine can be calculated easily from the equilibrium constant for this reaction. The effect of adding KBr is that it produces [itex]Br^-[/itex] ions in solution, shifting the equilibrium leftwards, resulting in more molecular bromine. Assuming KBr is highly ionic (ie : the dissociation constant is close to 1), one can then calculate [itex][Br_2]_{aq}[/itex].
[itex]~Br^+[/itex]? Weak as it is (pKa = 8.7) [itex]~HOBr[/itex] is an acid. Look for [itex]~OBr^-[/itex].
Chemical calculators for labs and education
BATE - pH calculations, titration curves, hydrolisis
Borek
Yes, it is; isn't it (duh) ? :redface: My bad !
Nobodys perfect... It is www.chembuddy.com, .pl was left from other project :blushing:
FAQ: Calculate the molarity of Br2 in the stock solution.
1. What is molarity?
Molarity is a unit of concentration that represents the number of moles of a solute dissolved in one liter of solution.
2. How do you calculate molarity?
Molarity is calculated by dividing the number of moles of solute by the volume of the solution in liters. The formula is M = moles of solute / liters of solution.
3. What is a stock solution?
A stock solution is a concentrated solution that is used to prepare more dilute solutions. It is typically a more cost-effective and efficient way to store and transport solutions.
4. How do you calculate the molarity of a stock solution?
To calculate the molarity of a stock solution, you need to know the volume and concentration of the stock solution, as well as the desired final volume and concentration. Use the formula M1V1 = M2V2, where M1 is the molarity of the stock solution, V1 is the volume of the stock solution, M2 is the desired molarity, and V2 is the desired volume.
5. How can you use molarity to prepare a solution with a specific concentration?
To prepare a solution with a specific concentration, you can use the formula C1V1 = C2V2, where C1 is the initial concentration, V1 is the initial volume, C2 is the desired concentration, and V2 is the desired final volume. This will help you determine the volume of stock solution and solvent needed to achieve the desired concentration.
