Calculate the net torque about the axle of a wheel
In summary, the problem involves calculating the net torque about the axle of a wheel, considering a friction torque of 0.45 m·N opposing the motion and a force of 18N. The 35N force appears to be tangential to the smaller wheel, so the angle of 135 degrees may need to be considered in finding its torque. The torque equation used is T=rFsin(), where r is the lever arm and F is the force.
ssjdbz101
Could someone explain this problem a little better to me.
Problem:
Calculate the net torque about the axle of the wheel shown in Fig. 8-39. Assume that a friction torque of 0.45 m·N opposes the motion and that F = 18.
*see attachment for picture.
I'm confused as how a wheel can have to forces (28N and 18N) on it in different directions on it at the same time.
Also, the 35N force looks like it is tangential to the smaller wheel, so do I have to use the 135 degrees in finding it's torque?
Torque equation: T=rFsin()
r=lever arm
F=force
Thanks in advance.
Torque is actually a cross product of r x F. To find the magnitude we've got:
[tex]\tau = rFsin(\theta)[/tex] Where theta is the angle between the moment arm (r) and the force.
So will the 135 degrees be an issue on the 35N force? It looks like the 35N force is tangential from the smaller radius.
I can provide some clarification on this problem for you. First, let's define some terms. Torque is the measure of a force's ability to rotate an object around an axis or pivot point. In this case, the axle of the wheel is the axis or pivot point. The net torque is the sum of all the individual torques acting on the object.
In this problem, there are three forces acting on the wheel: 28N, 18N, and 35N. The 28N and 18N forces are acting in opposite directions, so they will create a net torque that is the difference between the two forces. The 35N force is acting tangentially to the smaller wheel, so it will create a torque that is perpendicular to the radius of the smaller wheel.
To calculate the net torque about the axle, you will need to use the torque equation you provided: T = rFsin(). The lever arm, or distance from the axle to where the force is applied, will be different for each force. For the 28N and 18N forces, the lever arm will be the radius of the larger wheel. For the 35N force, the lever arm will be the radius of the smaller wheel.
To find the angle in the sin() function, you will need to use the 135 degrees given in the problem. This angle represents the angle between the force and the radius of the smaller wheel.
Once you have calculated the individual torques for each force, you can add them together to find the net torque about the axle. Remember to take into account the friction torque of 0.45 m·N, which will act in the opposite direction.
I hope this helps clarify the problem for you. If you have any further questions, please don't hesitate to ask. Good luck with your calculations!
FAQ: Calculate the net torque about the axle of a wheel
What is net torque?
Net torque is the overall twisting or rotational force acting on an object. It is the sum of all the individual torques acting on the object.
How is net torque calculated?
To calculate net torque, you need to know the magnitude of the force acting on the object, the distance from the axis of rotation to the point where the force is applied, and the angle between the force and the lever arm. The formula for calculating net torque is T = F x d x sinθ, where T is torque, F is force, d is distance, and θ is the angle between the force and the lever arm.
What is the importance of calculating net torque about the axle of a wheel?
The net torque about the axle of a wheel is important because it determines the rotational motion of the wheel. It helps us understand how much force is needed to rotate the wheel and in which direction it will rotate.
What factors can affect the net torque about the axle of a wheel?
The net torque about the axle of a wheel can be affected by the magnitude and direction of the applied force, the distance from the axis of rotation to the point where the force is applied, and the angle between the force and the lever arm. The mass and distribution of the weight of the wheel can also play a role in determining the net torque.
How can the net torque about the axle of a wheel be increased?
The net torque about the axle of a wheel can be increased by increasing the magnitude of the applied force, increasing the distance from the axis of rotation to the point where the force is applied, and increasing the angle between the force and the lever arm. Additionally, adding weight to the wheel or changing the distribution of weight can also increase the net torque.
