Calculate the pH of concentrated hydrochloric acid
  • Thread starter a.a
  • Tags
    Acid Ph
In summary, the conversation discusses the calculation of the pH of concentrated hydrochloric acid, which is 24.8% HCl by weight and has a density of 1.16 g/mL. The conversation also includes an attempt at solving the problem and a clarification on the meaning of "percent by weight." The final calculation results in a pH of -0.897, although it is noted that this method may not be accurate for highly concentrated solutions.
a.a
127
Calculate the pH of concentrated hydrochloric acid if this solution is 24.8 % HCl by weight and has a density of 1.16 g/mL.
\the percentage is throwing me of, can someone explain what it is?
I'm wildly guessing here, but if "percent by weight" somehow is supposed to mean "percent by mass," it would make things pretty easy; in 1.16g/mL, 28% of 1.16g would be HCl: (1.16g/mL)(0.28) = 0.3248g/mL.
From there, you can do some converting to eventually get to pH; I'll assume for now that only the percentage was tripping you up.
hey, useing what u told me i think i mite be getting somewhere:
n HCl = (0.248)*(1.16g)/(36.453g/mole) = 0.0789 moles
The molar concentration is thus [HCl] = (0.00789 moles)/(0.001 lit)
= 7.89M = [H+]
pH = -log([H+]) = -0.897
can someone verify?
Yes and no. Yes - you did your best and that's probably what your teacher wants. No - in such concentrated solutions pH can't be calculated this way. But that's not your fault and you can't do anything about it.
FAQ: Calculate the pH of concentrated hydrochloric acid
What is the formula for calculating the pH of concentrated hydrochloric acid?
The formula for calculating the pH of concentrated hydrochloric acid is pH = -log[H+], where [H+] represents the concentration of hydrogen ions in the acid solution.
What is the concentration of hydrogen ions in concentrated hydrochloric acid?
The concentration of hydrogen ions in concentrated hydrochloric acid is typically between 10 and 12 moles per liter.
How do I convert the concentration of hydrochloric acid to pH?
To convert the concentration of hydrochloric acid to pH, use the formula pH = -log[H+]. Simply plug in the concentration of hydrogen ions and calculate the negative logarithm to determine the pH.
What is the pH of a 1M solution of hydrochloric acid?
The pH of a 1M solution of hydrochloric acid is approximately 0. This is because a 1M solution has a hydrogen ion concentration of 1 mole per liter, which results in a pH of 0 when plugged into the pH formula.
Can the pH of concentrated hydrochloric acid change over time?
Yes, the pH of concentrated hydrochloric acid can change over time due to various factors such as temperature, concentration changes, and exposure to air. It is important to regularly measure the pH of the acid to ensure accurate results in experiments or industrial processes.
