Calculate the pressure drop of air across an orifice?
In summary, the three orifice flow program does not calculate piping pressure loss and so the pressure at the .375 orifice entrance is calculated to be 674.82 psig and the discharge pressure in the 2" pipe after the .375 orifice to be 8.56 psig. This calculation using the 12" pipe as the third orifice results in a .375 orifice discharge pressure of .01 psig.
smrodriguez4
Hi guys,
I don't know if you can help me, or if I am asking my question correctly but your feedback will be greatly appreciated. I have a 2" piping system that connects a scrubber that is rated for 675 psi (36" OD x 7'-4") to another scrubber rated for 75 psi (84"ID X 24'- 0") ; there is a .3/8" orifice plate in the system and roughly 100 ft of schedule 40 steel pipe between the vessels. The system does have high and low pressure alarms but I am trying to prove that in the remote case that the high pressure scrubber reaches 675 psi there will be enough pressure drop at the currently installed orifice plate to make the 75 psi scrubber safe. I know it will be safe because the low pressure scrubber has a 12" pipe going to a Flare but I want to make sure that we will never reach 75 psi if the high pressure scrubber reached operating limits.
How would you guys approach this situation? The gas flowing through the system is methane at 60F, I have estimated the flow by using a quick formula that estimates the amount of gas blown through a line puncture and it gave me 96,989 scf/Hr; I calculated this by assuming that the orifice was a line puncture of a system at 675 psi. This will be the choked flow rate at the orifice so this it should be the most flow rate that the system will see. I can then use that flow rate to calculate the Pressure drop due to piping friction but I am having a struggle calculating the pressure drop across the orifice.
Am I approaching the problem wrong? Or any ideas on how to calculate the DP?
In advance, thank you!
I have a three successive orifice flow program that I have; and, using this program with the 2" sch 40 pipe ID as the first orifice, the .375 orifice as second orifice and the 2" sch 40 pipe ID again for third orifice with 60F air and an upstream pressure of 675 psig.
This program does not calculate any piping pressure loss for the 2" pipe and without that effect the program calculated the pressure at the .375 orifice entrance to be 674.82 psig and the discharge pressure in the 2" pipe after the .375 orifice to be 8.56 psig with a flow rate of 1394 scfm (83,640 SCFH) which is very close to your calculated flow for the methane at 60F.
Clearly this is not a duplicate representation of your piping with a .375 Dia orifice because it does not include any piping losses but any added piping losses on the upstream 2" pipe will only serve to reduce the .375 dia orifice inlet pressure; and, piping losses downstream of the .375 orifice will have little effect due the fact the pressure ratio across the .375 orifice is far above the critical pressure ratio required to insure choked flow through the .375 orifice.
Just for interest I made a second calculation with the 12" pipe as the third orifice and the program calculated a .375 orifice discharge pressure of .01 psig for that final orifice diameter.
It is up to you to decide whether this three orifice flow result give you any comfort regarding the safety of your system; but, based upon the first calculation using the 2" pipe ID as the first and third orifices, it appears to be reasonable estimate the effect of the .375 orifice in terms of both pressure drop and flow rate on your system with the 675 psig upstream supply pressure.
One reassurance I can give you is that the program I used is based upon solid classical ideal gas flow equations and has proven to be accurate for predicting air three stage flow pressures through the inlet, nozzle and valve outlet combination on high pressure relief valves.
Related to Calculate the pressure drop of air across an orifice?
What is the formula for calculating the pressure drop of air across an orifice?
The formula for calculating the pressure drop of air across an orifice is: ΔP = 0.61 * (ρ * u²) * (A²/2 * d²) * Cd, where ΔP is the pressure drop, ρ is the density of air, u is the velocity of air, A is the area of the orifice, d is the diameter of the orifice, and Cd is the coefficient of discharge.
What is the coefficient of discharge and how does it affect the pressure drop?
The coefficient of discharge (Cd) is a dimensionless constant that takes into account the shape and size of the orifice, as well as the viscosity and compressibility of the fluid. It is used to adjust the theoretical pressure drop calculation to account for real-world conditions. A higher Cd value means a lower pressure drop, while a lower Cd value means a higher pressure drop.
How does the density of air affect the pressure drop across an orifice?
The density of air plays a significant role in determining the pressure drop across an orifice. As the density increases, the pressure drop also increases. This is because the air molecules are more tightly packed together, resulting in a higher resistance to flow and a greater pressure drop across the orifice. The density of air can be affected by factors such as temperature and altitude.
What factors can affect the velocity of air and therefore the pressure drop across an orifice?
The velocity of air is influenced by several factors, including the size and shape of the orifice, the flow rate of air, and the pressure difference across the orifice. Other factors that can affect air velocity and pressure drop include temperature, humidity, and the presence of obstructions or turbulence in the flow.
What are some common applications for calculating the pressure drop of air across an orifice?
The pressure drop of air across an orifice is a crucial factor in many industrial and engineering applications. It is commonly used in HVAC systems, compressed air systems, and ventilation systems to ensure efficient and effective air flow. It is also essential in applications such as gas flow meters, fuel injectors, and pneumatic equipment to control and measure air flow.
  • Mechanical Engineering
25K
