Calculate the tensile stress anpplied at maximum load
In summary, the steel cable to the hoist is 15m in length and has a diameter of 25mm. Its maximum load is 75kN, with a maximum permissible working stress of 200N/mm2 and a Young's modulus of elasticity of 210,000N/mm2. To determine the cross-sectional area of the cable, the pie R2 rule can be used, halving the diameter to get the radius. For parts 2, 3, 4, and 5, the equation sigma = F/A can be used, where sigma is the tensile stress, F is the maximum load, and A is the cross-sectional area. This can help determine the tensile stress applied to the cable
ashicus
(a) The steel cable to the hoist is 15m in length and has a diameter of 25mm. Its steel has a maximum permissible working stress of 200N/mm2 and a Young’s modulus of elasticity of 210,000N/mm2. The maximum load allowed on the hoist is 75kN. Determine the following:-
(i) the cross-sectional area of the cable
(ii) the tensile stress applied to the cable at maximum
load
(iii) whether the tensile stress is within permissible limits
(iv) the strain on the cable at maximum load
(v) the extension of the cable at maximum load.
Ive worked out the cross sectional area with the pie R2 rule but halved the 25mm to get the radius.
the exact answer that i got was pie X 12.5^2 = 490.8738521234052
i can't seem to find anywhere how to work out parts 2,3,4 or 5
can somebody help me please
Thanks
Ash
Part one is right although 5 significant figures is enough for this calculation. Are you currently taking a mechanics of materials course? Are you familiar with the equation:
[tex] \sigma = \frac{F}{A} [/tex]
If so, how do you think it applies to part 2?
Related to Calculate the tensile stress anpplied at maximum load
What is tensile stress?
Tensile stress is a type of mechanical stress that occurs when a material is pulled or stretched apart.
What is maximum load?
Maximum load refers to the maximum amount of force that can be applied to a material before it breaks or fails.
How do you calculate tensile stress at maximum load?
Tensile stress at maximum load can be calculated by dividing the maximum load by the cross-sectional area of the material.
What units are used to measure tensile stress?
Tensile stress is typically measured in units of force per unit area, such as pounds per square inch (psi) or newtons per square meter (N/m²).
Why is calculating tensile stress at maximum load important?
Calculating tensile stress at maximum load is important because it helps engineers and scientists understand the strength and durability of a material and determine whether it is suitable for a particular application or design.
11K
10K
