Calculate the torque about the potential pivot point
In summary, a 50 story building with a height of 200m and a base of 40m by 70m is being planned. It has a total mass of 1.8^7 kg and a weight of 1.8 x 10^8 N. With a 200 km/h wind exerting a force of 950 N/m^2 over the 70m wide face, the torque about the potential pivot point (rear edge of the building) is calculated to be -2.2x10^9 mN. The building will topple if the torque caused by the wind force (F_A) over the 200m X 70m face is greater than the torque of the building's
MAins
"A 50 story building is being planned. It is to be 200 m high with a base of 40 m by 70 m. Its total mass will be about 1.8^7 kg, and its weight therefore 1.8 x 10^8 N. Suppose a 200 km/h wind exerts a force of 950 N/m^2 over the 70 m wide face. Calculate the torque about the potential pivot point, the rear edge of the building (where F_E acts in) and determine whether the building will topple. Assume the total force of the wind acts at the midpoint of the building's face, and that the building is not anchored in bedrock."
Apparently the answer is
∑τ = F_A(1000 m) - mg(20 m) = -2.2x10^9 mN
but I have no idea how to derive this. Please explain!
∑τ = F_A(1000 m) do you mean F_A(100m)? - mg(20 m) = -2.2x10^9 mN
See above in red. If so, calculate the force of the wind (F_A) over the 200m X 70m face of ther building. What is the torque caused by the wind force about the rear edge of the 40 foot wide building? What is the torque of the building's weight about that edge? Which is greater? What does that imply?
As a scientist, it is important to first understand the given information and the physical principles involved before attempting to derive the solution. Let's break down the given information:
1. A 50 story building is being planned with a height of 200 m and a base of 40 m by 70 m. This means that the building is a rectangular prism with a height of 200 m, a length of 40 m, and a width of 70 m.
2. The total mass of the building is 1.8 x 10^7 kg, and its weight is therefore 1.8 x 10^8 N. This means that the building has a weight of 1.8 x 10^8 N acting downwards due to gravity.
3. A 200 km/h wind exerts a force of 950 N/m^2 over the 70 m wide face of the building. This means that the wind exerts a force of 950 N per square meter of the building's face.
4. The total force of the wind acts at the midpoint of the building's face. This means that the force of the wind is evenly distributed over the entire 70 m width of the building's face.
5. The building is not anchored in bedrock. This means that there is no external force acting to keep the building in place.
Now, let's use the principle of torque to calculate the torque about the potential pivot point, which is the rear edge of the building. Torque is defined as the product of a force and its lever arm, or the perpendicular distance from the pivot point to the line of action of the force. In this case, the pivot point is the rear edge of the building, the force is the wind force, and the lever arm is the distance from the pivot point to the midpoint of the building's face.
We can calculate the torque about the potential pivot point as follows:
∑τ = F x r
Where:
∑τ = total torque
F = force
r = lever arm
In this case, the force (F) is the wind force, which is 950 N/m^2. The lever arm (r) is half of the width of the building's face, or 35 m.
∑τ = (950 N/m^2) x (35 m) = 33,250 Nm
However, this calculation only gives us the torque about the midpoint of
FAQ: Calculate the torque about the potential pivot point
What is torque?
Torque is the measure of a force's ability to cause rotational motion about an axis. It is calculated by multiplying the force applied by the distance from the axis of rotation to the point of application of the force.
What is the potential pivot point?
The potential pivot point is the point around which an object can rotate. It is usually the point where the object is connected to a fixed support or where the object's weight is acting.
How do you calculate torque about the potential pivot point?
To calculate torque about the potential pivot point, you need to multiply the force applied by the distance from the pivot point to the point of application of the force. This can be represented by the equation T = F x d, where T is torque, F is force, and d is the distance.
What are the units of torque?
The units of torque are newton-meters (N⋅m) in the SI system and foot-pounds (ft⋅lb) in the imperial system.
How is torque used in real-life applications?
Torque is used in various real-life applications, such as in machines and engines. It is used to measure the rotational force needed to make an object rotate, which is important in the design and operation of many mechanical systems. In addition, torque is also used in sports, such as in measuring the force applied by a tennis player to hit a ball or the force applied by a pitcher to throw a ball.
