Calculate the total energy required to fly a drone on this flight plan
The discussion revolves around calculating the energy consumption of drone batteries based on flight parameters. Key inputs include current load during ascension, descent, and translation, as well as vertical speeds and battery specifications. Participants emphasize the importance of measuring CurrentLoadInFlight experimentally rather than relying solely on calculations, noting that factors like drone mass and wind speed significantly impact energy usage. There is also clarification that the formula presented refers to battery capacity in Amp-seconds rather than energy in Joules. Accurate energy consumption calculations require considering various dynamic factors beyond the initial inputs provided.
Xamaa
How much energy will drone batteries will consume if I have the following inputs,
By using provided GPS flight path data I've calculated total horizontal distance using Haversine formula, and multiplying this distance with provided horizantal speed I've total horizontal flying time. By multiplying ascend speed with total altitude (considering starting altitude is 0) I've calculated total ascending time, and same way using the descending speed I've calculated total descending time. By adding these 3 now I've the total flight time.
Now for further calculation I've following data inputs,
Code:
  "currentLoadInFlight": {
    "ascension": 0.020,
    "descent": 0.010,
    "translation": 0.015
  "forcedLandingCharge": 200
  "verticalSpeeds": {
    "ascension": 5.0,
    "descent": 1.0
  "energy": {
    "numberOfBatteries": 2,
    "capacity": 2000
  "payload": {
    "additionalLoad": 0.1
and details of these fields are as follows,
#configurations
[verticalSpeeds][ascension] the vertical speed of the drone during an ascension in meter / seconds (m/s)
[verticalSpeeds][descent] the vertical speed of the drone during a descent in meter / seconds (m/s)
[energy][numberOfBatteries] is the number of batteries mounted on the drone
[energy][capacity] is the capacity of the battery in milli Ampere Hour (mAh)
[payload][additionalLoad] is the extra load in in Ampere x Seconds ² / Meters ² (A.s²/m² ) caused by the payload (see [currentLoadInFlight])
#drones
[currentLoadInFlight] in Ampere x Seconds ² / Meters ² (A.s²/m² )
The current load in A per square unit of speed ((m/s)²) on the drone power system when it is flying
In vertical ascension [ascension]
In vertical descent [descent]
In horizontal translation [translation]
NOTE: We assume that this to remain constant thorough the mission.
[forcedLandingCharge] in milli Ampere Hour (mAh)
When the available charge is the batteries is less or equal to [forcedLandingCharge], the drone will land
Now considering energy can be calculated using,
Energy = Flight Time x CurrentLoadInFlight x Speed²
How do I calculate CurrentLoadInFlight and speed parameter?
Code:
    "ascension": 0.020,
    "descent": 0.010,
  "verticalSpeeds": {
    "ascension": 5.0,
    "descent": 1.0
  "energy": {
    "capacity": 2000
  "payload": {
and details of these fields are as follows,web hosting in Sri lanka[/color]
anyone here that can response my question, any kind of help would be appreciated thanks.
I see no way to calculate CurrentLoadInFlight . If the drone hovers so that the speed=0, it still uses energy. An inefficient drone uses more power than an efficient one. I think CurrentLoadInFlight is something that must be measured by experiment, not calculated.
I also miss seeing the drone mass in your calculations. It matters whether the drone weighs a ton or an ounce.
Where is wind speed?
Assuming a constant assent speed, the time is not the multiplication altitude and speed. The assent time is $$t= \frac{altitude}{speed}$$
You state
I realize now you actually mean battery capacity in Amp-s not energy as in Joules.
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
