Flucky
- 95
- 1
Calculate the wavelength of the n = 4 → 3 transition in 4He+ to an accuracy of 4 significant figures. (R∞=109 737 cm-1.) (Fine structure effects can be neglected.)
[itex] \frac{1}{λ} = \frac{m}{m_e} R_∞ (\frac{1}{n_1^2} - \frac{1}{n_2^2})[/itex]
where λ is wavelength, m is the reduced mass, and [itex]R_∞[/itex] is Rydberg constant (1.1x105 cm-1)
[itex] m = m_e \frac{m_N}{m_e + m_N} [/itex]
where m is the reduced mass, [itex]m_e[/itex] is mass of an electron, and mN is the mass of the nucleus.
In order to come out with a positive wavelength I set n1 to 3 and n2 to 4.
Now the problem I have is with the reduced mass, m. To try and make sense of it I did everything in SI units:
me = 9.11x10-31
mN = 2 protons + 2 neutrons = 2x(1.673x10-27 kg) + 2x(1.675x10-27 kg) = 6.696x10-27 kg
So that gives:
m = me x [itex]\frac{6.696x10^-27}{9.11x10-31 + 6.696x10^-27}[/itex] = 0.9999me
Plugging all the numbers in gives:
[itex]\frac{1}{λ}[/itex] = 5347 cm-1
∴ λ = 1.870x10-4 cm = 1.870x10-6 m = 1870 nmHowever the answer is 468.7 nm which means the reduced mass m should equal 3.99 me.
It's only a 1 mark question so I am obviously understanding it all wrong somewhere.
Any help would be very much appreciated.
