Calculate velocity of the fastest neutron inside a 96Mo nucl
In summary: However, if you are writing a paper for publication, you should ask a specialist in the field to check it for you.In summary, the calculation of the Fermi energy for a 96Mo nucleus results in a velocity of 0.2547 times the speed of light for the fastest neutron. This raises the question of whether or not it is safe to consider such nucleons in a non-relativistic way. While the Lorentz factor of 1.03 suggests that relativity may need to be taken into account, the fact that the neutron's energy is not close to its rest mass may indicate that it is not necessary. However, it is recommended to consult a specialist in the field for further clarification, especially if writing
says
594
Calculate the velocity of the fastest neutron in a 96Mo nucleus and, based on this, explain whether or not we are safe to consider such nucleons in a non-relativistic way. Hint: first
calculate the Fermi energy.
Fermi energy from Fermi gas model: https://en.m.wikipedia.org/wiki/Fermi_gas
Calculating the Fermi energy using Wolfram:
http://m.wolframalpha.com/input/?i=(hbar^2/(2*1.674929*10^-27kg))((3*pi^2((6*10^43)))/1m^3)^(2/3)
Fermi Energy = 30.3946 MeV
Fermi Momentum = √(2mE)
m: mass of neutron
E: Fermi energy
Fermi Momentum = √(2*939.565*30.3946) = 238.988 MeV/c
Velocity = Fermi Momentum / mass
= 238.988 MeV/c / 939.565Mev/c^2
= 0.2547c
So the fastest neutron in 96Mo is traveling at .2547 * speed of light. Provided my calculation is correct, I'm not sure whether we are safe to calculate them in a non-relativistic way though?
Ultimately it depends on what you are going to calculate and how accurately you need the answer. What does it give for the Lorenz factor? That might be a clue.
https://en.m.wikipedia.org/wiki/Relativistic_speed
says said:
I calculated the lorentz factor and got 1.03. I'm not sure if this means we are safe to consider the neutrons as non-relativistic though.
http://m.wolframalpha.com/input/?i=1/sqrt(1-(0.2547^2/1^2))
Yes, that's what I got. Borderline, I'd say. I can only repeat, it depends what question you are trying to answer, which perhaps says it is not safe to ignore it.
When you say 'borderline' what do you mean?
https://en.m.wikipedia.org/wiki/Fermi_gas#Relativistic_Fermi_gas
This says "For particles with energies close to their respective rest mass we have to use the equations of special relativity"
Considering the neutrons fermi energy is 30.3946 MeV and it's rest mass is 939.565Mev/c2 we could say its energy isn't close to it's rest mass.
Yes, that is certainly true. But it doesn't say that at only 3% it is safe not to. I'm really not sure.
If I had to gamble, I would opt for saying you do not need to consider relativity.
Related to Calculate velocity of the fastest neutron inside a 96Mo nucl
1. How do you calculate the velocity of the fastest neutron inside a 96Mo nucl?
The velocity of the fastest neutron inside a 96Mo nucl can be calculated using the formula: v = √(2 * E / m), where v is the velocity, E is the kinetic energy, and m is the mass of the neutron. This formula is derived from the principle of conservation of energy and momentum.
2. What is the mass of a neutron in a 96Mo nucl?
The mass of a neutron inside a 96Mo nucl is approximately 1.008665 atomic mass units (amu). This value may vary slightly depending on the isotopic composition of the nuclide.
3. How is the kinetic energy of the fastest neutron determined in a 96Mo nucl?
The kinetic energy of the fastest neutron inside a 96Mo nucl can be determined by measuring its speed and using the formula: E = 1/2 * m * v^2, where E is the kinetic energy, m is the mass of the neutron, and v is the velocity. This formula is derived from the classical equation for kinetic energy.
4. Can the velocity of the fastest neutron inside a 96Mo nucl be greater than the speed of light?
No, according to the theory of relativity, the speed of light is the maximum speed that can be achieved by any particle with mass. Therefore, the velocity of the fastest neutron inside a 96Mo nucl cannot exceed the speed of light.
5. How does the velocity of the fastest neutron inside a 96Mo nucl affect its stability?
The velocity of the fastest neutron inside a 96Mo nucl does not directly affect its stability. However, a higher velocity can result in a higher kinetic energy, which can potentially lead to nuclear reactions or decays. The stability of a nucleus is determined by the balance between the strong nuclear force and the electromagnetic force within the nucleus.
11K
