MHB Calculate volume of a solid rotating around the y-axis
The discussion centers on calculating the volume of a solid formed by rotating the area between the line y=1 and the function f(x)=3x/(x^2+1) around the y-axis. The user seeks to confirm the limits of integration and whether to integrate on both sides of the y-axis or simply multiply by two. They derive complex integrals and express confusion over their correctness, particularly regarding the limits found from solving f(x)=1. Another participant suggests using the method of cylindrical shells, providing formulas for shell height, circumference, and volume integration limits. The final volume expression involves integrating from the determined limits, emphasizing the need for clarity in the setup of the problem.
Nivelo
Sorry if i made any language errors, English isn't my first language.
Question: The limited area in the plane is created when the space between the line y=1 and the graph to the function f(x)=3*x/(x^2+1) rotates around the y-axis. Calculate the volume of the solid.I want to sum up all the circular discs that make up the body in order to get the volume. One disc has the
base area: pi*radius^2 * the height dy. Since its rotating around the y-axis i assume i first need to find the inverse by solving x from y since the radius is the distance from the y-axis and therefore x. I assume the limits of the x-axis is where f(x)=1 and when i solve this i get 4 points, 2 left of the y-axis and 2 right, which i listed below. Since i find the inverse and integrate over y i want the inverse limits. I get the lower limit to y=1 and the upper to y=3/2 (from finding maximum). The problem is i get a very complicated integral which makes me think its wrong and it also not the same as the correct answer.
I get the integral I=2*pi*integral from 1 to 3/2 of (3+sqrt(9-4*y^2)/(2*y))^2)dy)
My question is if my limits are correct and if i need to integrate on both sides of the y-axis or if i can mulitply by 2 instead.
I am a bit lost on this question and would appreciate some guidance in general. Can u give me some steps and data I've missed?
Limits x
X1=(-3/2)-sqrt(5/2)
X2=(-3/2)+sqrt(5/2
X3=(3/2)-sqrt(5/2
X4=(3/2)+sqrt(5/2
Any help is appreciated, thanks in advance!
recommend the method of cylindrical shells ...
shell height as a function of x
$h(x) = f(x)-1$
shell circumference as a function of x
$C(x) = 2\pi \cdot x$
shell thickness = $dx$
$\displaystyle dV = h(x) \cdot C(x) \cdot dx \implies V = \int_a^b h(x) \cdot C(x) \cdot dx$
determine the limits of integration, $a$ and $b$ ...
$\dfrac{3x}{x^2+1} = 1 \implies x = \dfrac{3 \pm \sqrt{5}}{2} \implies a = \dfrac{3 - \sqrt{5}}{2} \text{ and } b = \dfrac{3 + \sqrt{5}}{2}$
$$V = 2\pi \int_a^b \left(\dfrac{3x}{x^2+1}-1\right) \cdot x \, dx =2\pi \int_a^b 3 - \dfrac{3}{x^2+1}-x \, dx $$
There are probably loads of proofs of this online, but I do not want to cheat. Here is my attempt: Convexity says that $$f(\lambda a + (1-\lambda)b) \leq \lambda f(a) + (1-\lambda) f(b)$$ $$f(b + \lambda(a-b)) \leq f(b) + \lambda (f(a) - f(b))$$ We know from the intermediate value theorem that there exists a ##c \in (b,a)## such that $$\frac{f(a) - f(b)}{a-b} = f'(c).$$ Hence $$f(b + \lambda(a-b)) \leq f(b) + \lambda (a - b) f'(c))$$ $$\frac{f(b + \lambda(a-b)) - f(b)}{\lambda(a-b)}...
  • · Replies 20 ·
