MHB Calculate Volume of Solid of Revolution for y=sinx to y=cosx around y=2
The discussion focuses on calculating the volume of the solid formed by rotating the area between the curves y=sin(x) and y=cos(x) from x=π/2 to x=π around the line y=2. The washer method is identified as the appropriate technique, with the outer radius defined as R=2-cos(x) and the inner radius as r=2-sin(x). The volume differential is expressed as dV=π(R^2-r^2)dx, leading to the integration of the function to find the total volume. The final calculation yields a volume of 8π cubic units. This method effectively illustrates the application of calculus in determining volumes of solids of revolution.
MarkFL
MHB
Here is the question:
Volume obtained by rotating the region between y=sinx and y=cosx from x=pi/2 to x=pi around the line y=2?
Find the Volume obtained by rotating the region between y=sinx and y=cosx from x=pi/2 to x=pi around the line y=2.
I'm so confused about the y= 2 part, and help would be greatly appreciated!
Hint: Cos(x)^2-sin(x)^2=cos(2x)
I have posted a link there to this thread to the OP can view my work.
Mathematics news on Phys.org
Re: Brittney Mitchell's question at Yahoo! Answers: computing the volume of a sold of revolution
Hello Brittney Mitchell,
For problems of this nature, it is always a good idea to diagram the region to be revolved along with the axis of rotation so we can see what is involved. Please refer to the following sketch:
We can see that the washer method will work best for us here since both radii are defined as one function over the given domain. So, let's begin by stated the volume of an arbitrary washer:
$$dV=\pi\left(R^2-r^2 \right)\,dx$$
Now, the outer radius $R$ is the distance from the axis of rotation to the bottom curve which is $\cos(x)$, hence:
$$R=2-\cos(x)$$
And, the inner radius $r$ is the distance from the axis of rotation to the top curve which is $\sin(x)$, hence:
$$r=2-\sin(x)$$
And so we may write:
$$R^2-r^2=\left(2-\cos(x) \right)^2-\left(2-\sin(x) \right)^2$$
Using the difference of squares formula, we may state:
$$R^2-r^2=\left(4-\left(\sin(x)+\cos(x) \right) \right)\left(\sin(x)-\cos(x) \right)$$
Distributing, we obtain:
$$R^2-r^2=4\left(\sin(x)-\cos(x) \right)+\left(\cos^2(x)-\sin^2(x) \right)$$
And using a double-angle identity for cosine (the provided hint), we obtain:
$$R^2-r^2=4\left(\sin(x)-\cos(x) \right)+\cos(2x)$$
Thus, the volume of the arbitrary washer may be given as:
$$dV=\pi\left(4\left(\sin(x)-\cos(x) \right)+\cos(2x) \right)\,dx$$
And, summing up all the washers to get the volume of the described solid of revolution, we obtain:
$$V=\int_{\frac{\pi}{2}}^{\pi} 4\left(\sin(x)-\cos(x) \right)+\cos(2x)\,dx$$
Applying the FTOC, we get:
$$V=\pi\left[-4\left(\cos(x)+\sin(x) \right)-\frac{1}{2}\sin(2x) \right]_{\frac{\pi}{2}}^{\pi}$$
$$V=-\pi\left(\left(4((-1)+0)+0 \right)-\left(4(0+1)+0 \right) \right)=-\pi(-8)=8\pi$$
Thus, we find the volume of the solid in units cubed is $8\pi$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
