MHB Calculating 5-Star Ratings to Reach 4.85 Rating
  • Thread starter Thread starter loso6699
    Rating
To increase a current rating of 4.80 to 4.85, approximately 59 additional 5-star ratings are needed, based on a total of 1115 ratings. The calculation considers the average rating formula, where the sum of actual votes is divided by the total number of votes. If the number of actual votes is less than 1115, the required number of additional 5-star ratings may vary. For a more significant increase, such as to 4.90, a similar calculation can be applied with adjusted parameters. Understanding these calculations can help in strategizing for improved ratings.
loso6699
Hello guys I was going to ask a question regarding 5 star ratings its a hard one for me but it could be simple for you guys here it is,
I've got 1115 ratings ( 5 star max 1 lowest )
* What I know so far is my total rating is 4.80
* 696 of these are 5 star ratings
* some of the 1115 have not rated not sure how many but not too many 100-150 max i'd say
Questions, how many 5* ratings would I need to get rating up by 0.01 my aim is 4.85 rating or 4.9 to make it easier I just want a estimate to figure out where i'am
thanks
Mathematics news on Phys.org
thanks
Hi loso6699! Welcome to MHB! ;)
Suppose we have $N$ actual votes $x_i$ where $i=1..N$.
So $N \le 1115$.
Then the rating is:
$$\text{rating} = x_{average} = \frac {\displaystyle\sum_{i=1}^N x_i}N = 4.80$$
It follows that the sum of all actual votes is:
$$\sum_{i=1}^N x_i = 4.80 N$$
Now suppose we add $n$ extra votes of $5$ stars.
Then the new rating will be:
$$\frac {\displaystyle\sum_{i=1}^N x_i + 5n}{N+n} = \frac {4.80 N + 5n}{N+n} = 4.81 \quad\Rightarrow\quad
4.80 N + 5n = 4.81(N+n) \quad\Rightarrow\quad
(5 - 4.81)n = (4.81-4.80)N $$
So:
$$n = \frac{0.01 N}{5-4.81} \le \frac{0.01 \cdot 1115}{5-4.81} = 58.7
That means that with 59 extra votes of 5 stars, the rating is guaranteed to go up by 0.01.
If the actual votes was, say, 100 less, then we can do the same calculation with $1015$ instead of $1115$.
And if we want to go up by $0.05$, we can replace $0.01$ and $4.81$ by $0.05$ respectively $4.85$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
