Calculating a star's density profile
  • Thread starter Thread starter Angela G
    Density
The discussion focuses on solving for a star's density profile using the equation of hydrostatic equilibrium. The user initially integrates the equation but struggles with the right-hand side, which involves a non-uniform density profile expressed as ρ(r) = ρc(1 - r²/R²). They are advised to express the mass of the star as M = 4π∫₀ᴿ ρ(r) r² dr, rather than using the uniform density formula. Additionally, the importance of incorporating an equation of state relating pressure, density, and temperature is highlighted. The user expresses some confusion regarding gravitational potential but ultimately gains clarity on the relevant equations.
Angela G
Thread moved from the technical forums to the schoolwork forums
Hello!
I am trying to solve this problem but I'm struggling with it, could someone please help me?
The exercise is
A star with density profile: $$ \rho = \rho_c \left( 1- \frac{r^2}{R^2}\right)$$
a) What is the central pressure ##P_c## and the central temperature ##T_c## in terms of M and the ## \rho_c##?
b) What is the pressure profile ## P(r)## and the temperature profile ## T(r) ## in terms of ##P_c##, ##T_c## in addition to r and R
c) What is the value of ## \alpha## in the expression for the total gravitational energy $$ \Omega = - \frac{\alpha GM^2}{R}$$
$$\frac{d P}{d r} = - \frac{\rho Gm}{r^2}$$
$$ P = \frac{\rho k T}{\mu m_H}$$
$$ \Omega = - \int_0^M \frac{G m dm}{r} $$
to solve a) I used The equation of hydrostatic equilibrium $$ \frac{d P}{d r} = - \rho \frac{GM}{r^2} \iff dP = - \rho \frac{GM}{r^2}dr \Longrightarrow \int_{P_c}^0 dP = - \int_0^R \rho \frac{GM}{r^2} dr $$
I replaced M as ## \rho V ## and then
I integrated both the left and right-hand sides and got at the left-hand side ## - P_c##, But I'm stuck on the right-hand side. I calculated it and got $$ - \frac{4 \cdot 8 \pi}{3 \cdot 15} G \rho_c^2 R $$
I was thinking to replace R with the definition of density ## \rho = \frac{ 3M} { 4 \pi R^3} ## But I'm not sure how to proceed, some ideas?
The density profile is given as <br /> \rho(r) = \rho_c\left(1 - \frac{r^2}{R^2}\right). This is not uniform.
You have to start from the equation of hydrostatic equilibrium in the form <br /> \frac{dp}{dr} = -\rho(r) \frac{d\chi}{dr} where the gravitational potential \chi satisfies <br /> \frac{1}{r}\frac{d}{dr}\left(r\frac{d \chi}{dr}\right) = 4 \pi G \rho. Multiplying the first equation by r/\rho and differentiating with respect to r yields <br /> \frac{1}{r}\frac{d}{dr}\left(\frac{r}{\rho}\frac{dp}{dr}\right) = -4\pi G \rho. As the density is not uniform, the mass of the star is given by <br /> M = 4\pi\int_0^R \rho(r) r^2\,dr rather than M= (4/3)\pi R^3, which holds only for a uniform density.
I assume you have some equation of state which relates pressure, density and temperature. It would have been helpful to include that as a relevant equation.
Likes Delta2, Angela G and berkeman
yes, I'm sorry
For solving a) I have to do it with the hydrostatic equilibrium equation, to determine the pressure and to determine the temperature I have to use the expression I got from the pressure and use the ideal gas law ## P = \frac{\rho k T}{\mu m_H}##, for solving c) I think I should use the $$ \Omega = - \int_0^M \frac{G m dm}{r}$$ and then replace m with ## m = \rho V \Longrightarrow \frac{dm}{dr} = \frac{\rho}{dr} \frac{ dV}{dr} ##. I think this is the way to solve it because I did so in the last exercise, but in that case, the central density was ## \rho_c = \rho ##, so the mass could be replaced by ## \rho V(r) ##. but I will try your way, but I think I need a little more guidance because I do not understand that with the gravitational potential, I'm sorry that was a new sign😅😅
edit: I think I understood, thanks
For spherical coordinates, I think the left-hand side should be
<br /> \frac{1}{r^2}\frac{d}{dr}\left(r^2\frac{d \chi}{dr}\right) = 4 \pi G \rho.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
