Calculating Acceleration of a Block Going Down a 37 Degree Ramp Without Friction
In summary, the question was about finding the acceleration of a skier going down a slope with an angle of inclination of 37 degrees. The answer is found by setting the hypotenuse to 9.8 and calculating the opposite side. This is because the angle is measured with respect to the horizontal, and you want the component of the acceleration down the incline. This is done using trigonometry. The component of the acceleration down the incline is gravity, which varies depending on the angle of inclination. This is why the hypotenuse is set to 9.8. Ultimately, this is the direction the skier is moving and the component of the acceleration in that direction is what is needed to solve the problem.
guss
248
I had a problem where there is a block going down a slope with an angle of inclination of 37 degrees, and we did not need to account for friction.
The question was what is the acceleration of the skier.
I know how you figure out the answer, which is 5.89 m/s^2. I know you have to set the hypotenuse to 9.8 then figure out the opposite side, and that's easy enough.
But, why do you set the hypotenuse to 9.8? It doesn't make sense to me, and if this was the trend, then a ball rolling down a ramp with an angle of inclination of .1 degrees would have an acceleration of 9.8 m/s^2.
Anyone care to explain? Thanks.
The angle is measured with respect to the horizontal. So g*sinθ would be about 0.0017*g. It would roll very slowly down the incline, which is practically horizontal.
In general, you want the component of the acceleration down the incline. So the full acceleration would be g acting downward (and thus the hypotenuse of a right triangle) and the component parallel to the ramp would g*sinθ.
I still don't quite understand, sorry. What is the reason you want the component of the acceleration down the incline?
Because that's the direction the skier is moving, right?
Well, in this case the component of the acceleration (down the incline) is gravity. But that doesn't make sense to me because gravity should be vertical.
The acceleration down the incline would only be g if the incline were vertical. And it would be zero if the incline were horizontal. At all angles between vertical and horizontal, you need to use trig to calculate the component of g that is in the direction down the incline.
Oh, I see now. The way you put it made me realize how it works, now it seems obvious. Thanks all.
FAQ: Calculating Acceleration of a Block Going Down a 37 Degree Ramp Without Friction
What is the force that causes a block to go down a ramp?
In most cases, the force that causes a block to go down a ramp is gravity. The Earth's gravitational pull acts on the block, causing it to accelerate down the ramp.
How does the angle of the ramp affect the block's movement?
The steeper the ramp, the faster the block will accelerate down it. This is because a steeper angle creates a greater component of the gravitational force acting down the ramp.
Do all blocks go down ramps at the same speed?
No, the speed at which a block goes down a ramp depends on its mass and the angle of the ramp. A heavier block will move slower than a lighter block on the same ramp.
Is there any other force acting on the block besides gravity?
In most cases, the only other force acting on the block is friction. Friction opposes the movement of the block down the ramp, which is why a block will eventually come to a stop on a flat surface.
Can a block go up a ramp?
Yes, a block can go up a ramp if a force greater than gravity is acting on it. For example, if someone pushes the block up the ramp, it will move in the opposite direction of the force applied.
