InertialRef
- 25
A box rests on top of a flat bed truck. The box has a mass of m = 15.0 kg. The coefficient of static friction between the box and truck is μs = 0.8 and the coefficient of kinetic friction between the box and truck is μk = 0.63.
I had previously calculated in an earlier part of the question that the maximum acceleration acceleration the truck can have before the box starts to move is 7.84 m/s^2. When the truck is at that acceleration, and the box begins to slide. What is the acceleration of the box?
With the box still on the truck, the truck attains its maximum velocity. As the truck comes to a stop at the next stop light, what is the magnitude of the maximum deceleration the truck can have without the box sliding?
F = ma
Ff = μN
If the box is no longer at rest on the back of the truck, then the net force is no longer equal to zero. From the free body diagram that I drew, there are two forces acting upon the box. The forward force of the box as a result of the acceleration of the truck and the force of friction in the opposite direction.
Hence: Fnet = Fforward + Ffriction
The forward force would just be the mass of the box times the acceleration of the truck, and the Ffricton = 0.63 * 15.0 * 9.81. Since friction is in the opposite direction, the direction of the force would be negative. So,
Fnet = (15.0)(7.84) + [-(0.63)(15.0)(9.81)]
ma = 117.6 - 92.70
(15)a = 24.89
a = 24.89/15
a = 1.6597 m/s^s
However, this answer is wrong.
As for the second part of that question, the maximum negative acceleration of the truck should be simply -7.84 m/s^2, since that is the maximum positive acceleration the truck can have without the box sliding. This is wrong as well.
If someone could tell me where in my reasoning I'm making the mistake, that would be very much appreciated. :)
