Calculating acceleration using Newton's 3rd law
In summary: Again, it comes back to this issue of friction. The only reason that the duration of the push may matter is because it affects the coefficient of friction.
timelesstrix0
Member warned about posting without the homework template
So i have a challenging question given by my teacher:
Jimmy and Drake are at rest and on ice (therefore, we can ignore friction). Jimmy pushes
Drake for 0.50 seconds. Drake comes to rest 25 metres away from where they were at rest
10.0 seconds after the push.
Jimmy has a mass of 60 kg and Drake has a mass of 75 kg. How fast will Jimmy be going
after he has finished pushing Drake?!
i wana know how the "0.50 seconds" of push time will affect how i do the question...
Right now i can find Drake's acceleration and use that to find the force applied on Drake and use 3rd law and say that Jimmy will have the same amount of force... but idk if I am doing this right because i do not know how the 0.5 seconds of push time is involved in the question
for my velocity calculation (which will be used for the acceleration) will i have to use 0.5 seconds as the initial time value when doing
v = Δd/Δt
so it will be like: v = 25-0/10-0.5
If "we can ignore friction", what causes Drake to come to "rest 25 metres away"?
this part is very important -as the things started with it...
in this time interval Jimmy was pushing the drake ,so a force was being applied by J on D ; and Newtons Third law operates to say that The same force must have been applied by Drake on Jimmy for the same time interval - this leads to change in momenta of the two people
so Force .Time interval = change in momentum if the time involved is small and then you can proceed further.
Please double check you have stated the question accurately. As it stands, it makes no sense. If there is no friction, Drake will not come to rest. To figure out Jimmy's speed just after the push we need to find Drake's, and to find Drake's speed from the distance he takes to come to rest we need to know the coefficient of friction.
Likes drvrm
no i stated the question as it was given by my teacher (i copy pasted from the word document that my teacher gave us)
I overlooked that we know how long Drake takes to come to rest, so we can determine the coefficient of friction. All that is wrong with the question is that it should not say friction should be ignored.
The equation v=Δd/Δt gives the average velocity, not the initial or final velocity.
Are you familiar with the SUVAT equations? These apply when acceleration is constant, which it is here.
Also, note that the 10 seconds starts after the push ends, so do not subtract 0.5 from it.
so does the 0.5 seconds have a purpose when I am doing my calculations??
the reason for stopping velocity going to zero must be there
Not that I can see.
this time interval is the time during which pushing and reaction was being applied so this interval can be used in calculating the velocity acquired by Drake after which he traveled further and moreover the velocity acqired by jimmy can also be calculated .
one can equate the momenta also as the same force was being applied .
Again, it comes back to this issue of friction. The only reason that the duration of the push may matter is if there is a net external horizontal force acting during that period. If not, momentum is conserved during the push, and we can derive Jimmy's speed at end of push directly from Drake's. Since the two have different masses, the frictional force is different, so there is a small net horizontal force. I suspect the "friction can be ignored" clause was meant to apply to the duration of the push.
Related to Calculating acceleration using Newton's 3rd law
What is Newton's 3rd law?
Newton's 3rd law states that for every action, there is an equal and opposite reaction. This means that when one object exerts a force on another object, the second object will exert an equal but opposite force on the first object.
How does Newton's 3rd law relate to calculating acceleration?
Newton's 3rd law is essential in calculating acceleration because it helps determine the direction and magnitude of the forces acting on an object. By understanding the action-reaction pairs, we can accurately calculate the net force on an object and use Newton's second law (F=ma) to calculate its acceleration.
What are the steps for calculating acceleration using Newton's 3rd law?
The steps for calculating acceleration using Newton's 3rd law are as follows:
1. Identify the action and reaction forces acting on the object.
2. Determine the direction and magnitude of each force.
3. Use Newton's second law (F=ma) to calculate the net force on the object.
4. Use the net force and the object's mass to calculate its acceleration.
Can Newton's 3rd law be applied to all situations?
Yes, Newton's 3rd law can be applied to all situations. It is a fundamental law of physics that holds true in all cases, whether the objects are in motion or at rest.
How can understanding Newton's 3rd law improve our understanding of motion and forces?
Understanding Newton's 3rd law can improve our understanding of motion and forces by allowing us to accurately predict and calculate the effects of forces on objects. It also helps us understand that forces always occur in pairs and that every action has an equal and opposite reaction, leading to a better understanding of the interconnectedness of the physical world.
