MHB Calculating amount left at the end of a repetetive cutting down cycle.
  • Thread starter Thread starter Zekes
    Cutting Cycle
The discussion revolves around a repetitive process of replacing a larger number of characters (X's) with a smaller amount, specifically using a find-and-replace method. The example illustrates starting with 14 X's and replacing 8 with 5, resulting in a sequence of remaining amounts: 14, 11, 8, 5. A user seeks a more efficient way to calculate the remaining amounts when starting with 1,000,000 X's and applying a (99,90) replacement process. Additionally, there is a follow-up question about determining starting lengths that lead to an end length of 6 using a (7,3) process, emphasizing the need for simpler mathematical explanations. The conversation highlights the potential for simplifying calculations through understanding the underlying subtraction pattern.
Zekes
Let's say I have a group of X's characters that I want to cut down. I use a tool similar to 'find-and-replace-all', which takes an amount of X's each time, deletes them, and replaces them with another, smaller amount. For example, I can state that I want an amount of 8 X's to be replaced with 5 X's from an original amount of 14 X's. This cycle happens forever, or until there isn't a sufficient remainder left to replace anymore. To visualise the example I just provided:
  • (XXXXXXXX)XXXXXX --> [XXXXX]XXXXXX
    (XXXXXXXX)XXX --> [XXXXX]XXX
    (XXXXXXXX) --> [XXXXX]
So, you start with 14 X's and end with 5 X's, and the process carried out here can be summarised as '14, 11, 8, 5'. The process that was underwent in terms of finding and replacing can be described as (8,5) as 8 X's are replaced with 5 each time. Now, the question here is:
  1. When you initially have a string of 1,000,000 X's, and apply the find-and-replace process of (99,90), what is the summary of the process here?
    By summary of the process, I mean the '14, 11, 8, 5' which shows how many X's are left after each step.
I tried solving this manually, starting the process summary as '1,000,000, 909,091, 826,453, 751,321, 683,020, 620,929, 564,481, 513,172, 466,525' however I realized this was a very inefficient way of solving this, and prone to mistakes. Can anyone help me do it in a better, easier way?
ALSO FOLLOW UP QUESTION
  • For the (7,3) process, find all start lengths which eventually result in an end length of 6.
I can see 10 being applicable for this, however manual testing every number to find a suitable match is also quite inefficient. If you can help me for this question too, please do. Also, please explain in more simple math terms, rather than using symbols (as I am still a beginner) Thank you!
Mathematics news on Phys.org
Isn't this simply repeatingly subtracting 3 from 14 ?
14 - 3 = 11 - 3 = 8 - 3 = 5 ...whoa!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
