Calculating an n X n determinant
TGV320
Help in order to solve a determinant
Determinants
Hello,
I need some advice because I just can't figure out how to solve the problem. I could try to make the determinant triangular by adding all the b together, but that doen't seem a good way of solving the problem. Is there any direction I should be thinking of?
Thanks
Why not calculate the determinant for ##n = 2, 3, 4## and see whether a pattern emerges?
Likes TGV320, e_jane and topsquark
TGV320 said:
Homework Statement: Help in order to solve a determinant
Relevant Equations: Determinants
Hello,
View attachment 335323Thanks
Hint: Follow PeroK's advice and find the determinant by expanding along the bottom row.
-Dan
Likes TGV320, e_jane and PeroK
By considering the Leibniz formula, one can figure out that only some terms survive, where the permutations do not contain zeroes.
Likes TGV320 and topsquark
Multiply the ##i^{th}## row by ##-a_i## and add it to the first. You just need to see what the top left element will be.
Hi,
Thanks for the advice.
I have figured it out,though I never thought about getting the answer by experimenting on it, always thought it to n. That way of doing it with n=2 then 3 is quite illuminating.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
