Engineering Calculating angular acceleration
The discussion focuses on calculating angular acceleration using gravitational force and moment equations. The user calculates the gravitational force and moment but is confused about the resulting angular acceleration, which does not match their expected value. Other participants suggest providing a sketch for clarity and inquire about the coordinate system and the meaning of the symbols used. They also point out the unconventional units being used and emphasize the importance of consistency in unit application. Overall, the conversation highlights the need for clearer communication of the problem setup and consistent unit usage to resolve the calculation issue.
shreddinglicks
In Creo I have a pendulum modeled that is swinging. I want to calculate by hand the initial angular acceleration. Creo gives this value as 97.68 r/s^2.
Using Creo I know:
m = 5.26e-1 kg
A = 1.19e4 mm^2
distance from origin to centroid (0,-6.8e1,0)
g = 9806.6 mm/s^2
Centroid moment of inertia (Principal moment of inertia)
Ix' = 1.13e3
Iy' = 8.41e1
alpha = M / J angular acceleration
M = F*r where F is the gravity force
Parallel axis theorem
J = (Ix' + Iy') + [A*(dx^2 + dy^2)]
I calculate the gravity force
F = mg = (-9806.6)*(5.26e-1) = -5158 (mm^2*kg)/s^2
I get the moment
M = F*r = (-3.5e5)*(-6.81e1) = 3.5e5 (mm^2 * kg) / s^2 Where r is the y coordinate distance from origin to centroid
J = (Ix' + Iy') + [A*(dx^2 + dy^2)] = ([1.13e3] + [8.41e1]) + ([1.19e4]*([-6.81e1]^2)) = 5.52e7 kg*mm^2
alpha = M/J = 3.5e5 / 5.52e7 = 6.34e-3 1/s^2
What did I do wrong? I'm not getting my desired 97.68 r/s^2
Well, a sketch of the situation might help ...
There you could also indicate what coordinate system and the meaning of some of the symbols you use (instead of leaving us to guess). Is the rotation around one axis ? Then why the ##I_x## and ##I_y## ?
You use a funny set of units, but -- if you do it consistently -- that should be ok. Do you ?
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
