MHB Calculating Angular and Linear Speeds of Pulley and Belt
  • Thread starter Thread starter karush
    Belt Pulley
The discussion focuses on calculating the angular and linear speeds of a pulley with a radius of 12.96 cm, where 56 cm of belt travels around it in 18 seconds. The initial calculation for angular speed yielded approximately 0.34 rad/s, but further clarification revealed the correct angular speed is 0.24 rad/s. The linear speed of the belt was confirmed to be approximately 3.11 cm/s. Participants emphasized the importance of distinguishing between arc length and speed in calculations, as well as the correct notation for angular measurements. Overall, the conversation highlights common misunderstandings in physics notation and calculations.
karush
MHB
A pulley has a radius of $12.96\text { cm}$
it takes $18\text { s}$ for $56\text { cm}$ of belt to go around the pulley.
(a) find the angular speed of the pulley in $\displaystyle\frac{\text {rad}}{\text{s}}$
well from $\displaystyle\frac{56\text { cm}}{18\text{ s}}
\approx \frac{3.11\text { cm}}{\text{s}}$
and $\displaystyle\text {rad}=\frac{S}{r}
=\frac{3.11\text { cm}}{12.96\text { cm}}
\approx 0.34 \text{ rad}$
since $\text{S}$ is the arc length for one $\text{s}$ then
$\displaystyle\approx \frac{0.34\text {rad}}{\text{s}}$ angular speed
(b) find the linear speed of the belt in $\displaystyle\frac{\text {cm}}{\text{s}}
well if correct?? it seem a little bit choppy way to solve it.
Mathematics news on Phys.org
Yeah. It's a bit choppy. ;)
There is a difference between quantities and units.
Speed is a quantity, rad is a unit.
Note that rad is a rather special unit, since it's a dimensionless unit like "rev".
Take care though, since you have $2\pi \text{ rad}$ in one $\text{rev}$.
The usual symbol for the quantity angular speed is $\omega$, which has the unit $\text{rad/s}$.
Btw, can I assume that with S you meant the speed of the belt?
I'm asking since the usual symbol for speed is v.
Anyway, in that case you have for (a):
$$\omega = \frac S r = \frac {3.11\frac{\text{cm}}{\text{s}}}{12.96\text { cm}} = 0.24 \frac{\text{rad}}{\text{s}}$$
So I'm afraid your answer is not quite right, neither numerically, nor in the specification of the units.
Your answer for (b) is correct though.
OK, well, from the book i am looking at
$\text{s} = \text{arc length}$ so $\displaystyle\text{a}=\frac{s}{r}$
where $\text{r}=$ radius
and $\text{a}=$ angle in degrees or radians
this is confusing since $\text{s}$ looks like it is speed or seconds but is arc length
which I capitalized earlier to distinguish from speed or seconds.
so what is meant is.$\displaystyle\text {rad}=\frac{s}{r} =\frac{3.11\text { cm}}{12.96\text { cm}} \approx 0.34 \text{ rad}$
and so
$\displaystyle\omega = \frac{a}{t} = \frac {0.34\text{rad}}{sec}$
or is this fog over choppy waters
the notation is kinda well..
karush said:
ok, well, from the book i am looking at
and so
Ah okay.
Actually you can distinguish the distance $s$ from seconds $\text{s}$ by italic versus upright.
It's unusual though to use $a$ as an angle. The symbol $a$ is usually an acceleration. Angle is usually denoted as $\phi$ or $\theta$.
Anyway, what you should have is that in a period of $t=1\text{ s}$ the belt travels a distance $s=3.11\text { cm}$ along a radius $r=12.96\text { cm}$.
The corresponding angle is:
$$a =\frac{s}{r} =\frac{3.11\text { cm}}{12.96\text { cm}} = 0.24 \text{ rad}$$
Therefore the corresponding angular speed is:
$$\omega = \frac{a}{t} = 0.24 \frac {\text{rad}}{\text{s}}$$Alternatively you could say that in a period of $t=18\text{ s}$ the belt travels a distance $s=56\text{ cm}$ along a radius of $r=12.96\text { cm}$.
Then the corresponding angle is:
$$a =\frac{s}{r} =\frac{56\text { cm}}{12.96\text { cm}} = \frac{56}{12.96} \text{ rad}$$
And the corresponding angular speed is:
$$\omega = \frac{a}{t} = \frac {\frac{56}{12.96}}{18} \frac{\text{rad}}{\text{s}} = 0.24 \frac {\text{rad}}{\text{s}}$$
OK, think i am getting the picture... so .24 not .34 calc error
you were a great help these textbooks are sometimes shy on info to understand...
I post a couple more of these to make sure I have it down...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
14K
