Calculating area with the metric
In summary, when working with a 2D Riemannian manifold, we can use a coordinate system with the normal Euclidean metric to calculate the area spanned by two vectors. However, if we are using an arbitrary coordinate system with a non-Euclidean metric, we must first transform the vectors into the Euclidean metric coordinate system to calculate the area. In Riemannian geometry, we can cleverly remove the Euclidean metric from calculations by turning it into the metric that we do have. This is done through the use of the invariant volume element, √|g| d4x in four dimensions, and the area element, √|h| du1 du2, in two-dimensional surfaces.
Benjam:n
28
So say you have a 2D Riemannian manifold with a metric defined on it and for simplicity let's say its flat. That means there exists a coordinate system for which the metric tensor is the normal Euclidean metric everywhere. However let's say we are using an arbitrary coordinate system with a non Euclidean metric. So we have two vectors whose components are given in this arbitrary coordinate system. To work out the area we must transform both vectors into the coordinate system with the Euclidean metric and then work out the area spanned by the two vectors in that coordinate system, by taking the determinant of the matrix with those two vectors as the columns. My question is, usually in Riemannian geometry we don't know the coordinates with the Euclidean metric in terms of our coordinates so we cleverly remove it from calculations by turning it into the metric which we do have. How do you do that here?
The invariant volume element in four dimensions is √|g| d4x. Likewise for a two-dimensional surface, if you have surface coordinates u1 and u2 and surface metric hij, the area element is √|h| du1 du2.
Related to Calculating area with the metric
What is the metric system used for calculating area?
The metric system is a standardized system of measurement used in most countries around the world. It is based on the International System of Units (SI) and is used for measuring length, mass, volume, and area.
What are the units of measurement used in the metric system for area?
The units of measurement used in the metric system for area are square meters (m²), square centimeters (cm²), and square kilometers (km²). These units are based on the meter as the base unit of length.
How do you convert units of area in the metric system?
To convert units of area in the metric system, you simply multiply or divide by the appropriate conversion factor. For example, to convert from square meters to square centimeters, you would multiply by 10,000 (1 m² = 10,000 cm²).
What is the formula for calculating area with the metric system?
The formula for calculating area in the metric system is length x width. This means that you multiply the length of the object by its width to find the area in square meters.
What are some common tools used for measuring area in the metric system?
Some common tools used for measuring area in the metric system include rulers, measuring tapes, and meter sticks. More advanced tools such as laser distance meters and digital planimeters can also be used for precise measurements.
