Calculating Average Force of Bullet Impact on Block
In summary, the conversation discusses a problem involving a bullet hitting a wooden block and the task of finding the average force exerted by the block on the bullet. The solution involves using the law of conservation of energy and calculating the force using the formula for work, resulting in a final answer of 5184 Newtons.
Freaker
A bullet, having a mass of 18g and traveling with a velocity of 1200 m/s strikies a wooden block and pentrates 2.5m. What is the average force exerted by the block on the bullet?
W= F*total distance
W= .5*m*V2^2 - .5*m*V1^2
i got the answer -12960 J
The question is
Now your answer is in Joules..Force is in Newtons...so you missed something
Consider the law of conservation of energy;
The Kinetic energy lost by the bullet= Work done in moving the bullet 2.5m into the wooden block...
[tex]E_k=W[/tex]
now you know [itex]E_k=\frac{1}{2}mv^2[/itex] and you know [itex]W=Fs[/itex]
so you can find F
em i still don't think i have the right answer 43200 is that right
[tex]\frac{1}{2}*\frac{18}{1000}*1200^2=F*2.5[/tex]
And so
[tex]12960=2.5F =>F=5184N[/tex]
Related to Calculating Average Force of Bullet Impact on Block
1. How do you calculate the average force of bullet impact on a block?
The average force of bullet impact on a block can be calculated by dividing the momentum of the bullet by the time it takes for the bullet to come to a complete stop. This can be represented by the formula F = m*v/t, where F is the average force, m is the mass of the bullet, v is the velocity of the bullet, and t is the time of impact.
2. What is the importance of calculating the average force of bullet impact on a block?
Calculating the average force of bullet impact on a block is important for understanding the potential damage and penetration of the bullet. It can also help inform safety measures and improve the design of bullet-resistant materials.
3. What factors can affect the average force of bullet impact on a block?
The average force of bullet impact on a block can be affected by various factors such as the mass and velocity of the bullet, the density and thickness of the block, and the angle of impact.
4. Can the average force of bullet impact on a block be measured experimentally?
Yes, the average force of bullet impact on a block can be measured experimentally by using high-speed cameras and force sensors to capture the velocity and time of impact. This data can then be used to calculate the average force using the formula mentioned above.
5. How can the average force of bullet impact on a block be used in real-world scenarios?
The average force of bullet impact on a block can be used in real-world scenarios to assess the effectiveness of different types of ammunition and bullet-resistant materials. It can also be used to improve the design of body armor and other protective gear for law enforcement and military personnel.
