Calculating change in energy of a particle
In summary, the electron's potential energy decreases as it moves from an initial location with an electric potential of Vi = 30 V to a final location with an electric potential of Vf = 150 V. The change in potential energy is -1.92 * 10^-17 J, as the electron's potential energy at Vi is higher than at Vf. The book's answer of +1.92 * 10^-17 J is incorrect.
An electron moves from an initial location between parallel plates where the electric potential is Vi = 30 V and Vf = 150 V
a) Determine the change in the electrons potential energy
2. Equations
J/C = V = N/C * m
a) The electron is naturally moving to a location of higher energy, therefore its potential energy decreases as its kinetic energy increases.
Potential energy change = Ep2 - Ep1 = Vfq - Viq = q(Vf-Vi) = q(120 V) = -1.92 * 10^-17 J.
The sign makes sense to me, since the electron has more potential energy at Vi than Vf.
However, the book says the answer is +1.92*10^-17 J. Can someone help me out with why I am is wrong? Thanks
Well your book looks like its wrong. Your qualitative reasoning seems correct to me.
Likes 1 person
Are you sure they didn't ask for the change in kinetic energy? Because otherwise I have to agree with your answer as being negative.
Likes 1 person
Yes I'm sure they asked for potential energy. I guess the book is wrong. Thanks for confirming this.
Your solution is correct, the book may have made a mistake. The change in potential energy should indeed be negative, as the electron is moving from a location of higher potential to a location of lower potential. This means that the electron is losing potential energy and gaining kinetic energy. The sign of the change in potential energy is important as it indicates the direction of energy flow. In this case, the negative sign indicates that energy is leaving the system. Therefore, your solution is correct and the book's answer is likely a mistake.
FAQ: Calculating change in energy of a particle
What is the formula for calculating the change in energy of a particle?
The formula for calculating the change in energy of a particle is ∆E = E_final - E_initial, where ∆E represents the change in energy, E_final represents the final energy state, and E_initial represents the initial energy state.
How is the change in energy of a particle measured?
The change in energy of a particle is typically measured in joules (J) or electron volts (eV).
What factors contribute to the change in energy of a particle?
The change in energy of a particle can be influenced by factors such as the particle's mass, velocity, and its interaction with other particles or fields.
Can the change in energy of a particle be negative?
Yes, the change in energy of a particle can be negative if the final energy state is lower than the initial energy state. This indicates a decrease in energy.
How is the change in energy of a particle related to its motion?
The change in energy of a particle is directly related to its motion. As the particle moves, it can gain or lose energy, resulting in a change in its overall energy state.
