Calculating Clebsch-Gordan coefficients
In summary, the student is trying to calculate the Clebsch Gordan coefficients, but doesn't understand what the operators do or how to apply them.
Kara386
208
The question asks me to calculate the non-zero Clebsch Gordan coefficients
##\langle j_1+j_2, j_s-2|j_1,m_1;j_2,m_2\rangle##
Where ##j_s=j_1+j_2##.
The ##j_s-2## part is the ##m## of a ##|j,m\rangle## and I know that m has to equal ##m_1+m_2## or that equation would just be zero. And I also know that I should apply the lowering operators ##J_-## to one of these two equations:
##\langle j_s, j_s-1|j_1,j_1-1;j_2,j_2\rangle = \sqrt{\frac{j_1}{j_s}}##
Or
##\langle j_s, j_s-1|j_1,j_1;j_2,j_2-1\rangle = \sqrt{\frac{j_2}{j_s}}##
I don't know which of these two I should be applying the lowering operator to. And then I don't know how to apply it because there are two ##j, m## sets in the ket, so when calculating the coefficient using ##\sqrt{j+m}\sqrt{j-m+1}## which m and j exactly is this thing supposed to change? How do you apply the operator to an inner product? And you can't apply ##J_-## to the RHS so I'm not sure what to do about that either.
Essentially we're being taught via lots of examples, but it's hard to extract the rules from the examples without an explanation. Which is why my questions probably involve incredibly basic and fundamental concepts. Basically I have no idea what's going on, but it isn't for lack of reading or trying. I've definitely looked in lots of textbooks and on the internet, I just don't understand what they say! So any help is hugely appreciated, I'm trying to use this question to work out all the stuff I don't know. :)
Kara386 said:
How do you apply the operator to an inner product? And you can't apply J−J−J_- to the RHS so I'm not sure what to do about that either.
You can't, operators only act on kets.
To start, we have the convention
|j_1+j_2,j_1+j_2\rangle = |j_1,j_1;j_2,j_2\rangle
In order to get ##|j_1+j_2,j_1+j_2-2\rangle##, you have to apply ##(J_-)^2## to the left side and hence also to the right side. This gives you
(J_-)^2 |j_1+j_2,j_1+j_2\rangle = (J_-)^2 |j_1,j_1;j_2,j_2\rangle
Then project both sides by ##\langle j_1,m_2;j_2,m_2|##
\langle j_1,m_2;j_2,m_2|(J_-)^2 |j_1+j_2,j_1+j_2\rangle = \langle j_1,m_1;j_2,m_2|(J_-)^2 |j_1,j_1;j_2,j_2\rangle
In the end, it looks like that you should get a piecewise answer.
Likes Kara386
I don't know how to do the projecting thing. What I ended up with is:
##|j_s,j_s-2\rangle = \sqrt{\frac{2j_1(2j_1-1)}{j_s(4j_s-2)}} |j_1,j_1-2;j_2,j_2\rangle + \sqrt{\frac{2j_1j_2}{j_s(4j_s-2)}}|j_1,j_1-1;j_2,j_2-1\rangle + \sqrt{\frac{2j_2(2j_2-1)}{j_s(4j_s-2)}} |j_1,j_1;j_2,j_2-2\rangle + \sqrt{\frac{2j_1j_2}{j_s(4j_s-2)}}|j_1,j_1-1;j_2,j_2-1\rangle##
##=\sqrt{\frac{2j_1(2j_1-1)}{j_s(4j_s-2)}} |j_1,j_1-2;j_2,j_2\rangle + 2\sqrt{\frac{2j_1j_2}{j_s(4j_s-2)}}|j_1,j_1-1;j_2,j_2-1\rangle + \sqrt{\frac{2j_2(2j_2-1)}{j_s(4j_s-2)}} |j_1,j_1;j_2,j_2-2\rangle##
So when I do the inner product, what's the rule there? On the LHS it's the inner product of something with itself so do I get the square of the LHS? As for the RHS I know you can move the constants out from the middle so you get inner products there too, and in this basis all these vectors are orthogonal I think - except if they were the RHS would just be zero.
No, you are not projecting something on itself. You should project ##|j_s,j_s-2\rangle## onto ##\langle j_1,m_1;j_2m_2|##.
For example for the first term in RHS you get
\langle j_1,m_1;j_2m_2|j_1,j_1-2;j_2,j_2\rangle
What's the condition on ##m_1## and ##m_2## so that the above inner product does not vanish?
Likes Kara386
Oh, the inner product vanishes except for ##m=m_1+m_2##. Thanks! :)
Ah, except which one is m? If ##m = j_s -2## then none of them vanish.
I don't understand what you mean.
Likes Kara386
For an inner product to exist it has to have ##m_1+m_2=m##. I can identify ##m_1## and ##m_2## in the kets, but is ##m=j_s-2##? From the ket on the RHS? Or actually in this case ##m_1,m_2## are in the bra, but I still don't know which value is m. Do you get it from the RHS or from the ket which is part of the inner product?
It seems a bit strange to claim that the inner product doesn't vanish only if ##m_1+m_2=m## when you have no idea what ##m## stands for. Anyway, you should rethink what the condition is for an inner product not to be 0.
Likes Kara386
Well in my lecture notes there is ##\langle j,m|j_1,m_1;j_2,m_2\rangle = 0## unless ##m = m_1 + m_2##. It's just that I'm not entirely sure where to find the m in this scenario. I think it's #m = j_s-2##.
Yes, that's right. You have two bases you're dealing with here. One basis consists of eigenstates of total angular momentum ##\lvert j, m \rangle##; the other basis consists of states which are a product of the eigenstates of the individual angular momenta, i.e., ##\lvert j_1, m_1; j_2, m_2 \rangle##. Your notes say the state ##\lvert j, m \rangle## has no overlap with ##\lvert j_1, m_1; j_2, m_2 \rangle## if ##m \ne m_1+m_2##.
Look back at post #4. Is that the kind of inner product you're calculating for terms on the RHS? What kind of state is on the left and right of each product?
Likes Kara386
You might notice that in your expression for ##\lvert j_s, j_s-2\rangle## in terms of the other basis, the requirement that ##m = m_1 + m_2## is met for each of the terms on the RHS.
Likes Kara386
Ok, that isn't the right kind of inner product. On the way to my expression for the inner products I did find ##\langle j_s, j_s-1|j_1,j_1-1;j_2,j_2\rangle = \sqrt{\frac{j_1}{j_s}}## and ##\langle j_s, j_s-1|j_1,j_1;j_2,j_2-1\rangle = \sqrt{\frac{j_2}{j_s}}## and I do have the inner product
##\langle j_1, m_1; j_2, m_2|j_1, j_1-1; j_2,j_2-1\rangle## which looks a bit like that result combined, so could I apply that somehow? If these are bases then are the other two terms orthonormal, and so the inner product would be zero?
In the RHS, you have this form of inner product ##\langle j_1,m_1;j_2,m_2|j_1,m_1';j_2,m_2'\rangle##. In order for this not to be zero, how must the ##m##'s be connected between those in bra and those in ket?
Likes Kara386
Is it non-zero only for ##m_1 = m_1'## and ##m_2 = m_2'##?
yes.
Likes Kara386
blue_leaf77 said:
yes.
Ok, so then for the first inner product for example I'd need ##m_1 = j_1-2## and ##m_2 = j_2## for it to be non-zero, and I can write down similar things for the other inner products... should I know what ##m_1, m_2## are from somewhere? Because couldn't I just choose ##m_1 = j_1-2## and and ##m_2 = j_2##? That would make the other inner products zero, but that must be wrong because then if I chose to fulfil the conditions from another inner product I'd get a different answer.
Does that even make sense? Sorry if it's a silly question!
Kara386 said:
Ok, so then for the first inner product for example I'd need m1=j1−2m_1 = j_1-2 and m2=j2m_2 = j_2 for it to be non-zero, and I can write down similar things for the other inner products
Yes.
Indeed that should be the case, like I said in my first post you will have a piecewise solution. You can't express all three coefficients with only one common expression. There will be three conditions each with different answer for the inner product.
You can check if your answer is correct from Clebsch-Gordan coefficients table.
Likes Kara386
blue_leaf77 said:
Yes.
Taking the first inner product as an example, then. Set ##m_1 = j_1-2## and ##m_2 = j_2##. Then on the LHS I have
##\langle j_1, j_1-2; j_2, j_2|j_s, j_s-2\rangle##
Now that works in the sense that ##j_1 + j_2 =j##, and ##m = m_1+m_2##, so is that equal to 1?
No it wouldn't be, the inner product on the RHS is the one that's equal to 1.
The LHS will be ##\langle j_1,m_1;j_2,m_2|j_s,j_s-2\rangle## with ##m_1## and ##m_2## obeying certain condition that we just discussed about. The LHS is what is asked in your problem. One of the inner products in the RHS is one, the other vanish.
Related to Calculating Clebsch-Gordan coefficients
What are Clebsch-Gordan coefficients and why are they important in physics?
Clebsch-Gordan coefficients are mathematical factors that describe the coupling of angular momenta in quantum mechanics. They are important in physics because they allow us to calculate the probability of a system transitioning between different states.
How are Clebsch-Gordan coefficients calculated?
Clebsch-Gordan coefficients are calculated using the Clebsch-Gordan formula, which involves complex integrals and Clebsch-Gordan tables. These coefficients are typically calculated using computer programs or specialized software.
What is the significance of the term "recoupling" in Clebsch-Gordan coefficients?
The term "recoupling" refers to the process of combining two or more angular momenta to form a new total angular momentum. In the context of Clebsch-Gordan coefficients, recoupling refers to the mathematical operation that allows us to determine the probability of a system transitioning between different states.
Can Clebsch-Gordan coefficients be used to describe systems with more than two particles?
Yes, Clebsch-Gordan coefficients can be extended to systems with more than two particles. This involves calculating the coefficients for all possible combinations of angular momenta and coupling them together to form a total angular momentum. However, this process becomes increasingly complex as the number of particles increases.
What are some applications of Clebsch-Gordan coefficients in physics?
Clebsch-Gordan coefficients have numerous applications in physics, including in atomic and molecular physics, nuclear physics, and quantum field theory. They are also used in areas such as quantum computing and quantum information processing.
  • Quantum Physics
