Calculating Commutator of Differential Angular Momentum
In summary, Anders found that the commutators of angular momentum do not commute, and provided a summary of what he did to try and solve the problem.
Chem.Stud.
27
Hi there!
I have tried for hours to calculate the commutator of angular momentum in the differential form, but I cannot get the correct answer. This is my first experience with actually checking if two operators commutes, so there may be some beginner's misunderstandings that causes the problem.
I know from my textbook the correct answer:
[itex]
[\hat{L}_x,\hat{L}_y] = \frac{\hbar}{i}\hat{L}_z = \frac{\hbar}{i} \left( x \frac{\partial \psi}{\partial y} - y \frac{\partial \psi}{\partial x} \right)
[/itex]
The angular momenta are defined as
[itex]
\hat{L}_x = y \frac{\partial}{\partial z} - z \frac{\partial}{\partial y} \\
\hat{L}_y = z \frac{\partial}{\partial x} - x \frac{\partial}{\partial z} \\
\hat{L}_z = x \frac{\partial}{\partial y} - y \frac{\partial}{\partial x}
[/itex]
Sets up the commutator expression, and writes it out:
[itex]
[\hat{L}_x,\hat{L}_y] = \left[ y \frac{\partial}{\partial z} - z \frac{\partial}{\partial y} , z \frac{\partial}{\partial x} - x \frac{\partial}{\partial z} \right]
[/itex]
From what I assume is a well-known algebraic rule for handling commutators, I get the following:
[itex]
\left[y \frac{\hbar}{i} \frac{\partial}{\partial z}, z \frac{\hbar}{i} \frac{\partial}{\partial x} \right] - \left[y \frac{\hbar}{i} \frac{\partial}{\partial z}, x \frac{\hbar}{i} \frac{\partial}{\partial z} \right]
- \left[z \frac{\hbar}{i} \frac{\partial}{\partial y}, z \frac{\hbar}{i} \frac{\partial}{\partial x} \right]
+ \left[z \frac{\hbar}{i} \frac{\partial}{\partial y}, x \frac{\hbar}{i} \frac{\partial}{\partial z} \right]
[/itex]
It was straight forward to find that the two middle terms commute, i.e. they equal zero. Hence, we are left with:
[itex]
+ \left[z \frac{\hbar}{i} \frac{\partial}{\partial y}, x \frac{\hbar}{i} \frac{\partial}{\partial z} \right] \phantom{...} [1]
[/itex]
Upon evaluating these terms, I let them act on a function [itex] \psi [/itex]. Looking at the first term:
First I factored the complex fraction out. Then I wrote out the commutator and let each differential fraction act on [itex] \psi [/itex]:
[itex]
\frac{\hbar}{i} \left(y \frac{\partial \psi z}{\partial z} \frac{\partial \psi}{\partial x} - yz \frac{\partial \psi }{\partial x} \frac{\partial \psi}{\partial z} \right)
[/itex]
The y in the second term above can be factored out from the differentials, because the differential is not done with respect to y. In the first term, however, the z must be differentiated along with psi by using the product rule. Doing this, and cancelling equal terms of opposite sign, yields:
[itex]
\frac{\hbar}{i} y \psi \frac{\partial \psi}{\partial x}
[/itex]
Repeating this calculation for the second term in [1] yields
[itex]
-\frac{\hbar}{i} x \psi \frac{\partial \psi}{\partial y}
[/itex]
Substituting into [1] yields
[itex]
[\hat{L}_x,\hat{L}_y] \psi = \frac{\hbar}{i} \left( y \frac{\partial \psi}{\partial x} - x \frac{\partial \psi}{\partial y} \right) \psi
[/itex]
Now, comparing with the correct answer:
i) My signs are opposite of what they should be
ii) More importantly, I have a [itex] \psi [/itex] in the differentials which should not be there. My question is, "why, and how do I rid my answer of it?".
I hope I have sufficiently showed what I have done. I have checked my notes several times, and I cannot get rid of those extra psi's in my answer.
I would appreciate any help!
Regards,
Anders
[itex]
[/itex]
[A,B] ψ = A(Bψ) - B(Aψ)
Looks like you forgot the parentheses. Also there should be two factors of ħ/i in front, not one. (And just one ψ!)
For such cases, because it is a bit difficult not to make a mistake during your calculations, it's better to write some things in a more compact, yet known form...
For example, you could avoid so many [itex]\frac{h}{i} \frac{d}{dx_{i}}[/itex] by substituting them with [itex]p_{i}[/itex], for which you know its commutation relations with the coordinates [itex]x_{i}[/itex]
So for example the first parenthesis is:
[itex] [y p_{z},z p_{x}]= y [p_{z},zp_{x}]= y [p_{z},z] p_{x} = -ih y p_{x}[/itex]
The 2nd is:
[itex] [z p_{y},x p_{z}]= [z, xp_{z}] p_{y}= x [z,p_{z}] p_{y}= ih x p_{y}[/itex]
Also I don't understand why you have h/i twice in the commutators...where did they come from?
[itex] a [\hat{A},\hat{B}] \ne [a \hat{A},a \hat{B}][/itex]
Your main problem is that you are operating too soon on the wavefunction. Leave it right until the end.
You need to show
[itex]L_{z}= \frac{i}{h} [L_{x},L_{y}]=\frac{i}{h}[ y \frac{\partial}{\partial z}-z\frac{\partial}{\partial y}, z \frac{\partial}{\partial x}-x\frac{\partial}{\partial z}][/itex]
Now you should replace [itex]\frac{\partial}{\partial x_{j}} = \frac{i}{h} p_{j}[/itex]
[itex]\frac{i}{h} [L_{x},L_{y}]=\frac{i}{h}[ y \frac{i}{h} p_{z}-z\frac{i}{h} p_{y}, z \frac{i}{h} p_{x}-x\frac{i}{h} p_{z}][/itex]
[itex]\frac{i}{h} [L_{x},L_{y}]=(\frac{i}{h})^{3}[ y p_{z}-z p_{y}, z p_{x}-x p_{z}][/itex]
[itex]\frac{i}{h} [L_{x},L_{y}]=(\frac{i}{h})^{3}([ y p_{z}, z p_{x}]+ [ z p_{y}, x p_{z}])[/itex]
[itex]\frac{i}{h} [L_{x},L_{y}]=(\frac{i}{h})^{3}(-ih y p_{x}+ ih x p_{y})[/itex]
[itex]\frac{i}{h} [L_{x},L_{y}]=(\frac{i}{h})^{3}(-ih y \frac{h}{i} \frac{\partial}{\partial x}+ ih x \frac{h}{i} \frac{\partial}{\partial y})[/itex]
[itex]\frac{i}{h} [L_{x},L_{y}]=-\frac{i}{h}(- y \frac{\partial}{\partial x}+ x \frac{\partial}{\partial y})=\frac{i}{h} L_{z}[/itex]
But obviously your angular momenta are not well defined... For example, you know that angular momenta have dimensions of [itex]h[/itex], also you show partial derivatives in their definition (reminding me of momenta) which is not correct...
Another way to see that is by remembering that angular momenta are:
[itex]\vec{L}=\vec{r} \times \vec{p} [/itex]
which after the quantization of the momenta will get:
[itex]\vec{L}=\frac{h}{i} \vec{r} \times \vec{∇} [/itex]
with the cross giving the things you give as: xd_y - y d_x etc...
In fact the definitions you have given correspond to:
[itex] \frac{i L_{i}}{h}[/itex] in order to make them quantum operators...
with that definition:
[itex]\frac{i}{h} [\frac{ i L_{x}}{h}, \frac{i L_{y}}{h}]= \frac{i}{h} \frac{i L_{z}}{h}[/itex]
which will give you the
[itex] [L_{x},L_{y}]= \frac{h}{i}L_{z}[/itex]
I see where I went wrong. I have managed to get the correct answer. Thank you for your help!
FAQ: Calculating Commutator of Differential Angular Momentum
What is the commutator of differential angular momentum?
The commutator of differential angular momentum is a mathematical quantity that represents the difference between the two operators of angular momentum in a quantum mechanical system. It is defined as the difference between the product of the two operators and the product of the same operators in reverse order.
Why is calculating the commutator of differential angular momentum important?
Calculating the commutator of differential angular momentum is important because it helps us understand the fundamental principles of quantum mechanics and the behavior of particles at the subatomic level. It also allows us to make predictions about the properties of particles and their interactions.
How is the commutator of differential angular momentum calculated?
The commutator of differential angular momentum is calculated using the commutator formula, which involves taking the difference between the two operators and applying them to a wave function. This results in a new wave function that represents the difference between the original wave function and its transformed version.
What is the physical significance of the commutator of differential angular momentum?
The commutator of differential angular momentum has physical significance because it is related to the uncertainty principle in quantum mechanics. The value of the commutator determines the range of possible values for the two operators, and a non-zero commutator indicates that the two operators cannot be measured simultaneously with perfect accuracy.
How is the commutator of differential angular momentum used in quantum mechanics?
The commutator of differential angular momentum is used in quantum mechanics to determine the behavior of particles and their interactions. It is also used in the Schrödinger equation, which describes the evolution of quantum states over time. The commutator is an essential tool in understanding the principles of quantum mechanics and making predictions about the behavior of particles at the subatomic level.
