Calculating Current Flow in a Short-Circuited Battery
In summary, a 1.5 volt battery short-circuited by a 2-meter long wire with a resistance of 0.02 ohm per meter will result in a current flow of 37.5 amperes. It is important to properly express units in mathematical equations to avoid confusion.
kirsten_2009
137
[/B]
A 1.5 volt battery is short-circuited by a 2–meter long wire having a resistance of 0.02 ohm per meter. How large is the current flowing through the wire (before the wire or the battery burn out)?
Voltage = Ampere x Resistance
Ampere = Voltage/Resistance
Ampere = 1.5 V / 0.02 ohm x 2 m (0.04 ohm/m)
Ampere = 37.5 Amperes
"Ampere = 1.5 V / 0.02 ohm x 2 m (0.04 ohm/m)" is not really a good expression but yes, your answer is right and I think you clearly understand what you are doing even if you did not express it well mathematically. Without units, it's just 1.5/.04 = 37.5
You should express it mathematically in a way that makes the units come out right
kirsten_2009 said:
[/B]
Your answer is fine, but your work is a little off in the units. In the first line above, you have .02 ohm x 2 m, and get .04 ohm/m. The numbers are right, but the units aren't. They should be .02 ohm/m x 2 m, which results in .04 ohm, not ohm/m.
Some suggestions:
Instead of writing this -- 1.5 V / 0.02 ohm x 2 m (0.04 ohm/m) -- as 1.5 V /(0.02 ohm/m x 2m). In other words, use parentheses around the two factors in the denominator. If you write a/bc, most will interpret this as (a/b) times c, rather than a divided by (bc).
Oh O.k I see...thank you very much, I will adjust my units :)
The current flowing through the wire in this scenario would be 37.5 Amperes. This is a very high current, which could potentially cause the wire or the battery to burn out. It is important to note that short-circuiting a battery can be dangerous and should be avoided. In a real-world scenario, the current flow may also depend on the internal resistance of the battery and other factors such as temperature. It is always important to use caution and proper safety protocols when conducting experiments or calculations involving electrical circuits.
Related to Calculating Current Flow in a Short-Circuited Battery
1. How do you calculate the current flow in a short-circuited battery?
To calculate the current flow in a short-circuited battery, you can use Ohm's Law which states that current (I) is equal to voltage (V) divided by resistance (R). In a short-circuited battery, the resistance is very low, so the current will be very high.
2. What is a short-circuited battery?
A short-circuited battery is a battery that has a direct connection between its positive and negative terminals, bypassing the internal resistance. This results in a very low resistance and a high current flow, potentially causing damage to the battery and any connected devices.
3. Why is it important to calculate the current flow in a short-circuited battery?
Calculating the current flow in a short-circuited battery is important because it allows us to understand the potential damage and hazards associated with a short circuit. It also helps us determine the correct size and type of fuse or circuit breaker needed to protect the battery and connected devices.
4. What factors can affect the current flow in a short-circuited battery?
The current flow in a short-circuited battery can be affected by the battery's voltage, internal resistance, and the resistance of the short circuit. Other factors such as temperature and the type of battery can also play a role in determining the current flow.
5. Can the current flow in a short-circuited battery be controlled?
In most cases, the current flow in a short-circuited battery cannot be controlled as it is determined by the battery's internal resistance and the resistance of the short circuit. However, using proper safety measures and using the correct size and type of fuse or circuit breaker can help prevent damage and control the flow of current in the event of a short circuit.
