Calculating ΔE Difference for 2 Samples of Monatomic Ideal Gas
The discussion focuses on calculating the difference in internal energy (ΔE) for two samples of a monatomic ideal gas undergoing different processes but ending at the same final conditions of volume and pressure. It is established that since both samples start and end at the same state and can be assumed to have the same number of moles, the change in internal energy is path-independent and therefore the difference in ΔE is zero. The calculations for work done (W) in both samples are discussed, but the key takeaway is that the internal energy change does not depend on the path taken. Participants acknowledge the importance of recognizing the assumptions about the number of moles. The conversation concludes with a reaffirmation of the initial conclusion that the difference in ΔE is indeed zero.
hellowmad
for Ideal gas under different pathway
E = Q+W
PV = nRT
Question: Two samples of a monatomic ideal gas are in separate containers at the same conditions of pressure, volume, and temperature (V = 1.00 L and P = 1.00 atm). Both samples undergo changes in conditions and finish with V = 2.00 L and P = 2.00 atm. However, in the first sample, the volume is changed to 2.0 L while the pressure is kept constant, and then the pressure is increased to 2.00 atm while the volume remains constant. In the second sample, the opposite is done. The pressure is increased first, with constant volume, and then the volume is increased under constant pressure. Calculate the difference in delta E between the first sample and the second sample.for sample 1 is calculated by W = W1 +W2 = p1 delta(V) +0 = L atm, and for sample 2 W = 0+P2 deltaV = -2 L atm. But I have no idea how to calculate the Q for each samples.
Are you aware that the change in internal energy is path-independent? The statement of the problem does not say that the samples have the same number of moles, but you may assume that they do.
got it. I forgot it. in that case the different is zero as both share the same initial and final conditions. Thank you! great help!:smile:
You can infer that the number of moles is the same from
That's what Avogadro said. I should have listened more carefully.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
