Calculating Deviation of a Bullet's Trajectory
In summary, a bullet with a mass of 3.40g and a charge of 13.5 x 10^-9 C, traveling with a velocity of 160m/s perpendicular to Earth's magnetic field of 5x10^-5 T, will have a radius of motion of 8.05 x 10^11 m. After traveling 1.00km, the bullet will have a small deviation from its initial trajectory, which can be calculated using the equation ##R=\frac{mv}{qB}##.
davidbenari
466
A bullet (3.40g) has a velocity of 160m/s perpendicular to Earth's magnetic field 5x10^-5 T . The bullet has a charge of 13.5 x 10^-9 C.With what distance will it be deviated from its trajectory after it has traveled 1.00km?
##\vec{F}=q\vec{v}\times\vec{B}##
The way I visualise this problem. The bullet travels in circular motion.
It's radius of motion will be given by ##R=\frac{mv}{qB}=8.05\times 10^{11} m ##
With a radius this big, after it has traveled 1km it's almost perfectly on top of the line of its initial trajectory. Because this are my answers to the problem, I'm almost 100% sure I'm not doing it right.
It's certainly a small deviation, but it is not zero and can be calculated. The trick is to calculate it in such a way that you do not completely lose precision.
Please post an equation for the deviation.
Related to Calculating Deviation of a Bullet's Trajectory
1. What factors affect a bullet's trajectory?
The main factors that affect a bullet's trajectory are gravity, air resistance, and wind. Other factors, such as the bullet's weight, shape, and velocity, can also have an impact.
2. How do you calculate the deviation of a bullet's trajectory?
The deviation of a bullet's trajectory can be calculated by using the laws of physics, specifically the equations of motion. This involves considering the initial velocity, angle of launch, and environmental factors such as wind and air resistance.
3. What is the purpose of calculating deviation of a bullet's trajectory?
The purpose of calculating deviation of a bullet's trajectory is to determine where the bullet will ultimately land. This is important for accuracy in shooting sports and for making tactical decisions in combat situations.
4. Can the deviation of a bullet's trajectory be predicted accurately?
While the deviation of a bullet's trajectory can be calculated using mathematical equations and physics principles, it is not always possible to predict it with 100% accuracy. This is due to variables such as wind speed and direction, which can change quickly and affect the bullet's path.
5. How can the deviation of a bullet's trajectory be minimized?
The deviation of a bullet's trajectory can be minimized by taking into account environmental factors, such as wind and air resistance, and adjusting aim accordingly. Additionally, using a higher quality and more consistent ammunition can also help reduce deviation.
10K
