WPCareyDevil
- 30
An 85.0-N crate of apples sits at rest on a ramp that runs from the ground to the bed of a truck. The ramp is inclined at 27.0° to the ground.
(a) What is the normal force exerted on the crate by the ramp?(b) The interaction partner of this normal force has what magnitude and direction?(c) What is the static frictional force exerted on the crate by the ramp?(d) What is the minimum possible value of the coefficient of static friction?(e) The normal and frictional forces are perpendicular components of the contact force exerted on the crate by the ramp. What is the magnitude and direction of the contact force?
F=ma
Fr= (N)(k)
mag= sqrt(x^2+y^2)
dir= Tan^(-1) (y/x)
I solved everything except the last part (direction) of e.
a) Normal force: 75.3755N
b) Magnitude (partner of normal): 75.3755N, Direction: 62.999 degrees below the horizontal
c) Static friction force: 38.589N
d) coef of friction .50953
e) magnitude of contact force: 85.004N, ? degrees above the horizontalThe y component would be the normal force/partner [85cos(27)= 75.7355] while the x component is the friction/partner [85sin(27)=38.599]
(75.7355/38.599) * tan^(-1) = 84.18 degrees. Is this number correct, and I just need to account for it being above the horizontal? Or, am I off?
Thank you SO much for your time!
