Calculating drag for high mach numbers
  • Thread starter Thread starter LT72884
    Mach Rocket
At high Mach numbers, pressure drag becomes the dominant force affecting drag on high-powered rockets, making traditional drag equations less applicable. The drag coefficient encompasses both skin friction and form drag, and while the basic drag equation remains valid, it is primarily used to define the drag coefficient rather than calculate drag force directly. Additionally, wave drag becomes significant at these speeds and can be estimated mathematically. The discussion emphasizes the importance of understanding these dynamics for accurate drag calculations in high-speed flight. Overall, the conversation highlights the complexities of drag at varying Mach numbers and the need for precise modeling in rocket design.
LT72884
Ok, so i have a high powered rocket i made and it hits about 420 m/s
At low mach numbers, most the drag is due to skin friction, hence why you can solve for the Cd based on the Re and geometry alone (Dr. Gerald M. Gregoreks work shows this)
However, as soon as you hit higher mach numbers, pressure drag is the governing "force"
Meaning that Fd=(roh)(0.5)(A)(Cd)(v^2) is not really applicable anymore
So what is the new equation i should be using?
Thanks
https://en.wikipedia.org/wiki/Drag_coefficient said:
The drag coefficient of any object comprises the effects of the two basic contributors to fluid dynamic drag: skin friction and form drag. The drag coefficient of a lifting airfoil or hydrofoil also includes the effects of lift-induced drag. The drag coefficient of a complete structure such as an aircraft also includes the effects of interference drag.
Definition​
The drag coefficient is defined as
be358f44b989746a70ff5a96f5ea6ff4a242ea8b
So the equation is always applicable since, no matter the Mach number, there is always a drag force and a fluid density. The equation is used to define the drag coefficient, NOT to find the drag force.
In addition, at high Mach numbers, you get a wave drag component whose value can be estimated mathematically.
Likes russ_watters, LT72884 and berkeman
Thats what i thought. Though i have been informed differently a few times, and each time they do have a good explanation too.
Im hoping the other user, i think its Russ, will chime in.
I love learning and this is good stuff
Do you hear a sonic boom?
On some yes
Likes sophiecentaur
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
