MHB Calculating elasticity of substitution help
To calculate the elasticity of substitution between goods x and y for the function F(x,y) = 10x^2 + 15y^2, the Marginal Rate of Substitution (MRS) has been determined as 20x/30y. The elasticity of substitution can be expressed using the formula 1/(1-ρ), where ρ represents the power in the utility function. Clarification is needed on the value of ρ, as the book's answer of -1 suggests a specific interpretation of the function. The discussion highlights confusion regarding the application of the formula and the concept of ρ in calculating elasticity. Understanding these concepts is essential for accurately determining the elasticity of substitution.
bart11
Calculate the elasticity of substitution between y and x for F(x,y) = 10x^2 + 15y^2
I was able to calculate the Marginal Rate of Substitution as 20x/30y but I'm not sure how to proceed past that. The answer in the book is -1. Any and all help appreciated!
Mathematics news on Phys.org
denote rho as the power.
Then elasticity of substitution is
$\dfrac{1}{1-\rho}$
If the power is different, you would have to use the formula.
$\dfrac{1}{1-\rho}$
Sorry but I'm not sure if I follow. Rho? And I believe the book taught us using the formula so I may be a little confused. Thanks for the help!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
