Calculating Electric Potential of a Proton in Hydrogen Atom
In summary, the electric potential a distance of .5 x 10^-10 m from the proton of a hydrogen atom is -kQ/r2.
FelixISF
23
Find the electric potential a distance of .5 x 10^-10 m from the proton of a hydrogen atom
V= kQ/r
I know how to answer the question, because I know which equation to use. What I do not understand is, where the equation comes from ?
Could somebody bullet point the derivation of the equation (algebra, not calculus please )
Regards and Thanks!
Hi FelixISF! :smile:
FelixISF said:
V= kQ/r
It comes from the field (the force), which in this case is a Coulomb's law field.
The field has to be the gradient of the potential.
The field is -kQ/r2 in the r-direction, so the potential has to be kQ/r (plus a constant). :wink:
(That's calculus, of course … I don't understand what you mean by an algebra derivation :confused:)
I don't see how you go from -kQ/r^2 to kQ/r... Apart from the mathematical relation ship of the field being the gradient of the potential, I don't get the intuition behind it.
so field = -kQ/r^2 and potential = kQ/r
Now, there must be a relation between potential and field with which you can transform the field equation to the potential equation.. Do you understand what I am asking for?
Use the equation [tex]V=\int_{\infty}^{r}\vec{E}\cdot \vec{dl}[/tex] where V is the electric potential. In the case of a point charge you can substitute [tex]\vec{dl}=dr[/tex] and [tex]\vec{E}=E[/tex], so your integral becomes [tex]V=\int_{\infty}^r E \; dr[/tex].
In other words, potential energy is another name for work done (by a conservative force),
so electric potential difference = PE difference per charge = work done per charge = force times distance per charge = kQ/r2 times ∆r
thanks, that made it clear for me!
FAQ: Calculating Electric Potential of a Proton in Hydrogen Atom
What is the formula for calculating the electric potential of a proton in a hydrogen atom?
The formula for calculating the electric potential of a proton in a hydrogen atom is V = kQ/r, where V is the electric potential, k is the Coulomb's constant, Q is the charge of the proton, and r is the distance between the proton and the center of the atom.
How do you determine the value of the Coulomb's constant in the formula?
The value of the Coulomb's constant, k, is a fundamental constant in physics and is equal to 8.99 x 10^9 N*m^2/C^2. It can be found in most physics reference books or online.
What is the distance between the proton and the center of the hydrogen atom?
The distance between the proton and the center of the hydrogen atom is equal to the radius of the atom, which is approximately 0.0529 nanometers (nm).
How is the charge of the proton determined?
The charge of the proton is a fundamental constant in physics and is equal to 1.602 x 10^-19 Coulombs (C). It can be found in most physics reference books or online.
Can the formula for calculating electric potential be used for other atoms besides hydrogen?
Yes, the formula can be used for other atoms as well, but the values of the Coulomb's constant and the charge of the proton may be different depending on the atom. Additionally, for multi-electron atoms, the calculation becomes more complex as the electric potential is affected by the charges of all the electrons in the atom.
