erok81
- 464
Electrons are accelerated through a 20 V potential difference, producing a mono energetic beam. This is directed at a double-slit apparatus of 0.010mm slit separation. A bank of electron detectors is 10m beyond the double slit. With slit 1 alone open, 100 electrons per second are detected at all detectors. With slit 2 alone open, 900 electron per second are detected at all detectors. Now both slits are open.
The first minimum in the electron count occurs at detector X. How far is it from the center of the interference pattern?
dsinθ=mλ
λ=h/p
First we will need to find λ. Using the de Broglie wavelength can calculate this. However, I am stuck here.
Electron volts were introduced this semester without any direction so I don't really know how to use them. I know that an electron volt is the kinetic energy obtained by acclerating an electron over a 1V potential. So I am assuming that to find the KE in this case I can multiply 20 by 1.60x10-19 and I will have KE in eV. Now first sticking point - how is this translated to momentum? I know the mass and KE...so I would need a velocity?
Next I am not sure how covering and uncovering affects the calculations. I understand how it affects the pattern, but that's about it. Although from my optics class do I need to know this? I can solve for theta which will give me my distance from the center...
So summarized. I need help converting my calculated eV to momentum - if I even calculated eV correctly and also how covering and uncovering the slits plays into solving this problem.
