Calculating electrostatic pressure
In summary: The electric field creates a torque on the electrons, and the energy of this torque is the work done resisting it. This is equivalent to adding up the individual contributions to the electric field torque, and then multiplying by the appropriate force (in this case, the Coulomb force).In summary, the electric pressure needs to be equal to one atmosphere for a spherical balloon with radius of 1.0 m to be charged with the same number of electrons as required to create an electric field of one atmosphere.
June_cosmo
25
Calculating electrostatic pressure. A spherical balloon with radius 1.0 m is made of aluminum-coated Mylar. How many electrons must be deposited on the aluminum layer such that the resulting electric pressure is equal to one atmosphere?
Assume q is the total charge of electrons needed, on the sphere using Gauss's Law, ##\vec E=\frac {q}{4\pi R^2 \epsilon}\hat r##. For one infinitesimal on sphere, ##\vec F=\vec E*d_q, where F=F_{atmosphere}##
I checked out other questions and found this method may not be right..
Maybe it is similar to the process of pressurizing a balloon by adding more and more gas to it it, that is the "electric pressure" increases as more and more electrons are brought onto the surface of the balloon? According to Wiki an electrostatic pressure is exerted on a section of a surface charge on a conductor due to the electric field, E, at that point. Strangely enough it says that this pressure tends to push the surface charge into the conductor's surface? As far as I know the electric field is perpendicular to the surface of the conductor. Which makes this statement difficult to understand. I see that this problem is also discussed in the "Electrostatic pressure" Similar discussion link below.
The charges all repel each other so it is clear that there is a force acting to push the balloon's surface outward. For example, think of a thin strip about the "equator" - all the charges repel each other so they're trying to get away from each other radially outwards. (That's why, on a charged solid sphere, they're all on the ouside surface!)
OK, as to the quantitaive aspect - I suggest considering virtual work! From an energy viewpoint this is not a difficult problem.
FAQ: Calculating electrostatic pressure
What is electrostatic pressure?
Electrostatic pressure is the force per unit area acting between two charged objects. It is caused by the repulsion or attraction of electric charges.
How is electrostatic pressure calculated?
Electrostatic pressure is calculated using the formula P = kq1q2/r2, where P is the electrostatic pressure, k is the Coulomb's constant (9x10^9 Nm^2/C^2), q1 and q2 are the magnitudes of the charges, and r is the distance between the charges.
What is the unit of measurement for electrostatic pressure?
Electrostatic pressure is measured in pascals (Pa) or newtons per square meter (N/m^2).
How does distance affect electrostatic pressure?
The electrostatic pressure is inversely proportional to the square of the distance between the charges. This means that as the distance increases, the electrostatic pressure decreases.
What are some real-life applications of calculating electrostatic pressure?
Electrostatic pressure is used in many everyday devices, such as air purifiers, spray guns, and inkjet printers. It is also essential in understanding the behavior of lightning and designing high-voltage equipment.
