Calculating Energy of Radiation in Proton-Antiproton Annihilation
  • Thread starter ProPatto16
In summary, in proton-antiproton annihilation, a proton and an antiproton collide and disappear, producing electromagnetic radiation. The total energy of the radiation can be calculated using the equation E=mc2, where m is the mass of each particle (1.67*10-27) and c is the speed of light (2.998*108). The result is 3.002*10-10 joules or 1.87GeV. This method is correct, but it is possible that the number of marks for the question is a misprint.
ProPatto16
326
in proton-antiproton annihilation a proton and an antiproton collide and disappear producing electromagnetiv radiation. if each particle has a mass of 1.67*10-27 and they are at rest just before collision, find total energy of radiation and give answer in joules and electron volts.
rest energy, E=mc2
E = [1.67*10-27 x (2.998*108)2] x 2
= 3.002*10-10 J
= 1.87GeV
is that right? the question is for 10 marks and it just seems to easy??
Your method is correct as far as I can tell. Two photons would have to be produced to conserve momentum but the question does ask for the total energy.
Perhaps the number of marks is a misprint.
Related to Calculating Energy of Radiation in Proton-Antiproton Annihilation
1. What does it mean when something is "too simple to be right"?
When something is considered "too simple to be right", it means that it is so straightforward or easy to understand that it may seem unrealistic or incorrect. It suggests that the solution or explanation is oversimplified and may not accurately reflect the complexities of the situation.
2. How can we determine if something is "too simple to be right"?
Determining whether something is "too simple to be right" can be challenging and may require further research or analysis. One approach is to critically evaluate the evidence and consider alternative explanations. If the solution or explanation does not account for all the available evidence or if there are discrepancies, it may be too simple to be accurate.
3. Can something that is "too simple to be right" still be true?
Yes, it is possible for something that is considered "too simple to be right" to still be true. However, it is important to thoroughly examine and test the solution or explanation to ensure that it is accurate and accounts for all the available evidence. Sometimes, what may seem like a simple solution may actually be the correct one.
4. Why is it important to avoid oversimplifying things?
Oversimplifying things can be problematic because it may lead to incorrect or incomplete conclusions. It may also overlook important details or factors that could significantly impact the situation. In science, it is crucial to consider all the evidence and complexities involved to arrive at accurate and reliable conclusions.
5. How can we strike a balance between simplicity and accuracy in science?
Finding a balance between simplicity and accuracy in science can be challenging, but it is essential. One approach is to continuously evaluate and test the solution or explanation to ensure that it is supported by the available evidence. It is also helpful to communicate clearly and transparently, acknowledging any limitations or uncertainties in the findings.
