Calculating Energy Released When Hydrogen & Anti-Hydrogen Collide
  • Thread starter Mike12345
  • Tags
    E=mc^2
In summary, the energy released when a hydrogen atom collides with an anti-hydrogen atom can be calculated using the formula E=mc^2. However, in order to get an accurate result, the atomic weight of the hydrogen atom should be converted into a mass figure. The energy released will not be zero, but the exact amount depends on the speed at which the collision occurs. If it happens at a relativistic speed, the energy released would be 2E, while at a slower speed it would be 2(mc^2).
Mike12345
So theirs this question
Particle accelerators can be used to accelerate particles up to 95% the speed of light. Determine the energy released when 1 hydrogen atom collides with an anti-hydrogen atom.
E=mc^2
= (1.00794)(2.998x10^8 x 0.95)^2
= 1.00794 x 8.1225 x 10^ 16
= 8.1869 x 10^16
I know this is wrong
When an anti hydrogen and hydrogen collide is the result 0?
The atomic weight of a hydrogen atom, 1.00794, should be converted into an actual mass figure, probably kg, in order to get E.
you really need to make it clear what units you are using. you seem to be mixing them.
your calculation is wrong, but the energy released will not be zero.
the energy of an atom moving with (relativistic) momentum p and rest mass m is given by:
E^2 = (cp)^2 + (mc^2)^2
(note the c in mc^2 never changes, that is, you should never replace it with .95c or anything else)
and the same would be true for an anti-atom. so, in theory, you could get 2E out of such a collision, but certainly some of that will be converted back to mass very quickly if such a collision were to actually take place (that's what i think anyway).
if you assume the collision happens at a slower (non-relativistic) speed, then the total energy released would be:
E = 2(mc^2)
hope this helps
I would like to clarify that the equation E=mc^2 is used to calculate the energy released from a mass, not from a collision. In this case, the collision between a hydrogen atom and an anti-hydrogen atom would result in the annihilation of both particles, releasing a large amount of energy in the form of gamma rays. The exact amount of energy released would depend on the masses of the particles involved. However, it is important to note that this type of collision is not currently possible to create in a particle accelerator due to the difficulty of producing and containing anti-hydrogen atoms.
FAQ: Calculating Energy Released When Hydrogen & Anti-Hydrogen Collide
What is the process of calculating energy released when hydrogen and anti-hydrogen collide?
The process of calculating the energy released when hydrogen and anti-hydrogen collide involves using the formula E=mc², where E is the energy released, m is the mass of the particles, and c is the speed of light. This formula is based on Einstein's theory of relativity and can be used to calculate the energy released from any type of matter-antimatter collision.
How do you determine the mass of hydrogen and anti-hydrogen in this calculation?
The mass of hydrogen and anti-hydrogen can be determined by using the atomic mass of hydrogen (1.008 atomic mass units) and the atomic mass of anti-hydrogen (1.008 atomic mass units). These values can then be converted to kilograms and used in the E=mc² formula.
Is the energy released from a hydrogen-anti-hydrogen collision always the same?
No, the energy released from a hydrogen-anti-hydrogen collision can vary depending on the speed and angle of the collision, as well as any other factors that may affect the mass or energy of the particles. The E=mc² formula provides an estimate of the maximum amount of energy that can be released, but the actual energy released may be less.
How does the energy released from a hydrogen-anti-hydrogen collision compare to other types of particle collisions?
The energy released from a hydrogen-anti-hydrogen collision is much greater than that of other types of particle collisions, such as proton-proton collisions. This is because hydrogen and anti-hydrogen have equal and opposite charges, resulting in a more powerful release of energy when they collide and annihilate each other.
What practical applications does this calculation have?
The calculation of energy released from a hydrogen-anti-hydrogen collision is important for understanding the fundamental laws of physics and the behavior of matter and antimatter. It can also have practical applications in fields such as nuclear physics and energy production, as well as in the development of advanced propulsion systems for space travel.
