Calculating Error from an Experiment
In summary, the error expression for v is δv = |v| (δs/|s| + |√(g/2h)| [|1/2| (δg/|g| + δ2h/|2h|)] / |√(g/2h)|).
Scholesy
From v = s×√(g/2h), where s is distance, g is gravity, and h is height, what would the expression of error for v?
My physics lab manual gives the following equations to help out-
multiplication rule- z= xy
limit error for the above: δz= |z| (δx/|x| + δy/|y|)
division rule- z = x/y
limit error for the above: same as multiplication rule
exact power- z=x^n
limit error for the above: δz= |z|[|n| (δx/|x|)]
What I did was try and use those equations and fit them to the equation I'm trying to solve for, the v= ... one.
So my attempts are:
δv= |v|(δs/|s| +(δ√(g/2h))/|√(g/2h)| )
Then I would need to use the exact power rule for the square root portion but that's where I get stuck because the format calls for z = x^n. In terms of (sqrt) g/2h, x is g/2h, n is 1/2, but what would z be?
Thanks for any help
I would first clarify the question and ask for more information. What is the context of this equation? What are the units for each variable? Is this a theoretical equation or one that has been experimentally derived? Without this information, it is difficult to determine the appropriate error expression for v.
Assuming that this is a theoretical equation, I would approach the problem by first identifying the independent and dependent variables. In this case, the independent variables are s, g, and h, and the dependent variable is v. I would then use the multiplication rule to determine the error expression for v.
δv = |v| (δs/|s| + δ√(g/2h)/|√(g/2h)|)
To find the error for √(g/2h), I would use the exact power rule, with z = √(g/2h), x = g/2h, and n = 1/2.
δ√(g/2h) = |√(g/2h)| [|1/2| (δ(g/2h)/|g/2h|)]
To find δ(g/2h), I would use the division rule, with z = g/2h, x = g, and y = 2h.
δ(g/2h) = |g/2h| (δg/|g| + δ2h/|2h|)
Finally, I would substitute this expression into the original equation to get the final error expression for v:
This may seem complicated, but it is important to accurately account for the errors in each variable in order to obtain a reliable error expression for v. It would also be helpful to double check the units for each variable to make sure they are consistent with the units for v.
Calculating error in an experiment is an important step in ensuring the accuracy and reliability of your results. From the given equation, we can see that the velocity (v) is dependent on the distance (s), gravity (g), and height (h). Therefore, the error in v will be affected by the errors in these variables.
Using the multiplication rule, we can write the expression for the error in v as:
As you have correctly identified, we need to use the exact power rule for the square root portion. In this case, z would be the square root of g/2h, which can be written as z = (g/2h)^(1/2). Therefore, the error in v can be expressed as:
δv = |v| (δs/|s| + |(g/2h)^(1/2)| (δ(g/2h)/|(g/2h)|))
I would also recommend using the division rule to simplify the expression further. This would give you:
δv = |v| (δs/|s| + (1/2) δ(g/2h)/|(g/2h)|)
I hope this helps you in calculating the error in v. Remember to always consider the errors in all the variables when calculating the error in your final result.
Related to Calculating Error from an Experiment
1. What is the purpose of calculating error from an experiment?
The purpose of calculating error from an experiment is to determine the accuracy and precision of the experimental results. It allows scientists to understand the degree of uncertainty in their measurements and make more informed conclusions about their findings.
2. How is error calculated from an experiment?
Error is typically calculated by finding the difference between the experimental value and the accepted value, and then dividing that difference by the accepted value. This value is then multiplied by 100 to represent the error as a percentage.
3. What is the difference between absolute and relative error?
Absolute error is the numerical difference between the experimental value and the accepted value, while relative error is the absolute error divided by the accepted value. Relative error is often expressed as a percentage and gives a better understanding of the accuracy of the experiment, as it takes into account the magnitude of the values being compared.
4. How does systematic error differ from random error?
Systematic error is caused by consistent factors that affect the accuracy of the experiment, such as faulty equipment or incorrect experimental procedures. Random error, on the other hand, is caused by unpredictable fluctuations in measurements and can be reduced by taking multiple measurements and averaging the results.
5. How can error be minimized in an experiment?
Error can be minimized by ensuring that all equipment used in the experiment is functioning properly, following precise and accurate experimental procedures, and taking multiple measurements to account for random error. It is also important to use appropriate units and significant figures in calculations to reduce error.
