MHB Calculating Executive Committee Possibilities for a Board of 12 Directors
  • Thread starter Thread starter alexmahone
The discussion revolves around calculating the number of ways to form an executive committee from a board of 12 directors, including the roles of president and treasurer. The initial approach suggests using the formula for non-zero subsets, yielding $2^{12}-1$, but this does not account for the specific titles. A more nuanced calculation considers the scenarios where the same person can hold both titles or where different individuals occupy the roles, leading to a total of $39 \cdot 2^{12}$ for distinct roles. The final interpretation includes both single-member committees and combinations of larger committees, resulting in a complex formula that accounts for all possible configurations. The discussion highlights the importance of clarifying the interpretation of roles in committee formation.
alexmahone
A company’s board of directors has 12 members. The board must select an executive committee of
any nonzero size, consisting of a president and treasurer (these titles may or may not be conferred to
the same person). How many possible ways are there to do this?
My attempt:
The answer is the number of non-zero subsets of the board of directors, which is $2^{12}-1$. Is this correct?
I just realized that the committee {1, 2, 3, 4, 5, 6} where 1 is the president and treasurer is probably different from the committee {1, 2, 3, 4, 5, 6} where 2 is the president and treasurer. This complicates the problem.
My attempt:
Yes, I agree if we do not consider the titles to be conferred:
$$N=\sum_{k=1}^{12}\left({12 \choose k}\right)=2^{12}-1$$
However, if we also add in the titles, I think we need:
$$N=\sum_{k=1}^{12}\left({k \choose 2}\cdot{12 \choose k}\right)=67584$$
edit: I just realized I did not account for the same person holding both titles...so perhaps it should be:
$$N=12+\sum_{k=2}^{12}\left({k \choose 2}\cdot{12 \choose k}+k\right)=67673$$
Could you please explain this?
My attempt:
The answer to problems of this sort often depend on how you interpret the question. In this case, are you just concerned with the choice of individuals in the committee, or does the description of the committee include specifying which individual/s have the positions of president and treasurer? If for example the committee consists of three directors, call them A, B and C, then anyone of those three could be the president, and anyone of them could be the treasurer. I would interpret that as giving nine different committees, although they all have the same set of members. But your answer counts that as just one committee.
If your interpretation of the question is correct then so is your answer. But my answer would be very different, as follows. If a single member acts as both president and treasurer then there are $$12$$ ways to choose that person, and $$2^{11}$$ possible ways to complete the committee from a subset of the remaining directors. If the president and treasurer are different, then there are $12$ ways to choose the president, $11$ ways to choose the treasurer, and $$2^{10}$$ possible ways to complete the committee. That gives a total of $$12\cdot2^{11} + 132\cdot2^{10} = 39\cdot2^{12}$$ for my answer to the question.
Edit. I somehow overlooked previous comments when posting that. I now see that the problem of how to interpret the question has already been raised.
I will explain my reasoning for my latest version, added after you quoted my post:
The first term ($12$) is the number of 1 person commitees, where naturally that single person (for which we have 12 choices) holds both titles.
Now the sum begins with all the two person committees...where we first consider the number of ways to choose 2 from 12, AND the number of ways to choose 2 from 2 and then we add 2 because there are two ways for each of those 2 people to hold both titles. And the sum continues in like manner for the committees making up 3-12 people.
Does this make sense?
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
