Calculating Expected Return and Standard Deviation of Combined Investment
In summary, the combined investment has an expected return of 7.5 and a standard deviation of 1.118033988749895. To find the smallest range that will contain the future return with probability 8/9, Chebychev's theorem must be used since the return distribution is not assumed to be normal.
needhelp83
199
Let X and Y be the per dollar return of 2 stocks. Suppose that both have an expected return of 0.05, both have a variance of 0.0009 and covariance(X,Y)= -0.001. Suppose that you invest $50 in the stock with return X and $100 in the stock having return Y
1) Calculate the expected return of your combined investment. Calculate the standard deviation
2) Provide the smallest centered at your expected return that will contain your future return with probability 8/9. (HINT: Since you many not assume that the return distribution is normal, you must use Chebychev's theorem)
For number 1) is this simply adding up 0.05 *2??
1)E[Return] = E[50X] + E[100Y] = (50*.05)+(100*.05)=7.5
The standard deviation is:
Var(Return) = Var(50X+100Y)= 502Var(X) + 1002Var(Y)+ 2*(50)*(100)*Cov(X,Y) = 1.25
[tex]\sqrt{1.25}=1.118[/tex]
FAQ: Calculating Expected Return and Standard Deviation of Combined Investment
What is the formula for calculating expected return and standard deviation of combined investment?
The formula for calculating expected return is the sum of each individual investment's expected return multiplied by its respective weight. The formula for calculating standard deviation is the square root of the sum of each individual investment's weight multiplied by its respective standard deviation squared.
How do you determine the weight of each individual investment?
The weight of each individual investment is determined by dividing the amount invested in that particular investment by the total amount invested in all investments.
What is the significance of calculating expected return and standard deviation of combined investment?
Calculating expected return and standard deviation of combined investment allows investors to assess the potential return and risk of a portfolio. This information can help in making informed investment decisions and managing risk.
Can expected return and standard deviation be used to predict future performance of a combined investment?
No, expected return and standard deviation are not guarantees of future performance. They are based on historical data and do not account for unforeseen events or market fluctuations.
How can an investor use the information from calculating expected return and standard deviation?
An investor can use the information to compare different investment options and determine which combination of investments aligns with their risk tolerance and investment goals. It can also help in diversifying a portfolio to minimize risk.
