Calculating Flux Density: 400-Turn Coil with GO Steel Core and Current of 500mA
  • Thread starter Thread starter nobunaga
    Density Flux
To calculate the flux density for a 400-turn coil with a GO steel core and a current of 500mA, the relevant parameters include the number of turns (N=400), current (I=0.05A), and coil length (l=0.03m). The magnetic force (F) is calculated as 20 At. The flux (Φ) can be determined using the formula Φ=F/Rm, where Rm represents the magnetic reluctance. The cross-sectional area (A) is necessary for calculating the flux density (B=Φ/A), which is currently missing from the discussion. Accurate calculations require all parameters, including the cross-sectional area, to determine the flux density effectively.
nobunaga
A 400 turn coil wound over a length of 30mm has a core GO steel and has a current of 500mA
flowing through it. Find the density of the flux produced.
N=400, I=0.05, l=0.03 F= IN ; Φ=F/Rm ; B=Φ/A ; Rm=
F=20 At
I believe that " A " is missing
A = the cross sectional area in metres squared
  • · Replies 43 ·
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 31 ·
