B Calculating Force of Ball-Spring Collision
To calculate the force of a ball-spring collision, one must consider the mass of the ball and the spring constant. The force can be determined using F = dp/dt, but requires knowledge of the time duration of the collision. Clarification is needed on whether the maximum force, average force, or a function of force over time is desired for the calculation. Understanding the specifics of the collision dynamics will influence the approach to solving the problem. Accurate calculations depend on these parameters and definitions.
AdvaitDhingra
Let's assume I have a ball moving at a constant velocity and it collides with a spring and the spring compresses n cm. If I know how much mass the ball has and the spring constant D, how would I calculate the Force? I mean since F = dp/dt I would have to know the time in which the stopping occured. How can I solve this?
Do you want the maximum force, the average force (time-averaged, or distance-averaged), or the function ##F(t)##?
Likes nasu and Dale
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
