Calculating frequencies and velocity
In summary, you calculate the emitted frequency by taking the average of the coming and going frequencies.
catfish
[Mentor's note - This thread was moved here from a non-homework forum, therefore it does not use the template.]
Hi guys
Need some help answering questions about frequencies and calculating velocity.
I'm given two frequencies: 470Hz for an approaching object, 440Hz for when the object is moving away. Velocity of the speed of sound is 343m/s. Work out the frequency of the sound at the object. The receiver is stationary. What formula do I use to work this out?
And once that's been calculated, can velocity be calculated using this formula? fr = fs(v/(v – vs)) where fr is frequency heard by the receiver, fs is frequency from the sender, v is velocity of sound through air, and vs is velocity of the object.
Any help is appreciated.
I think this belongs in the homework and coursework part of the forum, but anyway..
The first equation here:
http://en.wikipedia.org/wiki/Doppler_effect
plug in you data for the two cases (coming and going), you'll have a pair of linear equations, solve them for the two unknowns (Velocity of source and emitted frequency).
There is a much faster, intuitive way of getting emitted frequency ( and then Vs) which will hopefully become obvious when you see it's value after calculating it the longer way...
I've got an answer for my first question. Is it supposed to be 455Hz?
catfish, I think we also need to know if the speed of the object when it's moving away is equal or not to the speed when the object is approaching.
I think it's assumed that it is but I apparently also have to work out the speed of the object using the information and the formula provided.
Yes, it's just the average of the coming and going frequency: (470+440)/2
Now just plug some numbers in and solve for Vs
Sweet, thanks for the help.
Related to Calculating frequencies and velocity
1. What is the formula for calculating frequency?
The formula for calculating frequency is f = 1/T, where f is frequency and T is the period of the wave.
2. How do you calculate the velocity of a wave?
The velocity of a wave can be calculated by multiplying the wavelength (λ) by the frequency (f), or by dividing the distance traveled by the time it took to travel that distance.
3. What units are typically used to measure frequency?
Frequency is typically measured in Hertz (Hz), which is equivalent to one cycle per second.
4. Can you calculate the frequency and velocity of a wave without knowing the wavelength?
No, in order to calculate frequency and velocity of a wave, the wavelength must also be known or able to be measured.
5. How does changing the frequency affect the velocity of a wave?
The velocity of a wave is not affected by changes in frequency, as long as the medium through which the wave is traveling remains constant.
