MHB Calculating Frequency, Midpoint, Relative Frequency and Cumulative Frequency
  • Thread starter Thread starter freedomdorm
    Frequency Relative
To calculate frequency, midpoint, relative frequency, and cumulative frequency for the class intervals 0-9, 10-19, 20-29, 30-39, and 40-49, start by determining the number of data points that fall within each range to establish frequency. The midpoint for each class can be found by averaging the lower and upper limits of the intervals. Relative frequency is calculated by dividing the frequency of each class by the total number of data points. Cumulative frequency is obtained by adding the frequency of each class to the sum of the frequencies of all preceding classes. This structured approach allows for effective data analysis within the specified ranges.
freedomdorm
I like Serena said:
Hi rihnavy! Welcome to MHB! ;)
By dividing the range into 5 equal parts.
The minimum is 0 and the maximum is 49.
So pick 0-9, 10-19, 20-29, 30-39, 40-49.
Hello,
If the lowest class limit is 0-9 then how do I figure out the frequency, Midpoint, Relative frequency, and cumulative frequency?
Mathematics news on Phys.org
freedomdorm said:
Hello,
Hey freedomdorm!
I saw you posted this update on to another question so I gave you your own thread. Are you curious about the other question or do you have a new problem you'd like us to look at? :)
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
11K
14K
