Calculating Friction & Coefficient: 0.50 kg Block on 30° Ramp
To determine the force of friction opposing a 0.50 kg block sliding down a 30° ramp with an acceleration of 2.0 m/s², the net force is calculated using the equation F = ma. The gravitational force acting on the block is broken into components, with the parallel component being 0.5mg * sin(30°) and the normal force as mg * cos(30°). The required frictional force is found by rearranging the equation to F = 0.5mg - ma. The coefficient of friction is then calculated using the relationship F(friction) = F(normal) * coefficient of friction. This analysis leads to the conclusion that both the force of friction and the coefficient of friction can be determined through these calculations.
runningirl
A block of mass 0.50 kg slides down a 30 degree ramp.
a) What force of friction opposes the motion of the block in order to make the acceleration equal to 2.0 m/s/s?
b) What coefficient of friction is necessary in order to accomplish this?
f=ma
net force=(9.8*.5)*sin30
2.45=.5(a)
a=4.9 m/s/s?
Horizontal component of weight is mgsin(30) = 0.5mg
normal component = mgcos(30) = sqrt(3) * mg/2
0.5mg - F = ma
So F = 0.5mg - ma, we found F
Also F = mu * sqrt(3) * mg/2
mu = F/(sqrt(3) * mg/2)
Use F=ma to find the force needed. a is 2 and m is 0.5. Then break the black's force of gravity into components qith trig. Subtract the force from F=ma from the force going down the ramp to get frictional force. The difference between the forces must be from friction. Simply find the normal force and use F(friction)= F(normal)(coefficient of friction)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
