Calculating Friction & Time for a Bullet Penetrating Rubber
A 7.80 g bullet traveling at 500 m/s penetrates a block of solid rubber to a depth of 4.50 cm, prompting a calculation of the average frictional force exerted on it. To find this force, work and energy principles should be applied, assuming the frictional force remains constant. The average force can be determined using the change in momentum divided by the time taken for the bullet to stop. Additionally, the elapsed time for the bullet's penetration can be calculated under the same assumption of constant friction. Properly framing the question is crucial for accurate calculations in physics.
shin
A 7.80 g bullet is initially moving at 500 m/s just before it penetrates a block of solid rubber to a depth of 4.50 cm.
(a)What is the magnitude of the average frictional force (in N) that is exerted on the bullet while it is moving through the block of solid rubber? Use work and energy considerations to obtain your answer.
(b)Assuming the frictional force is constant, how much time (in s) elapses between the moment the bullet enters the block of solid rubber and the moment it stops moving?
Hello @shin ,
:welcome: !​
Here at PF things don't go as you seem to expect: dump an exercise and get the answer.
Please read the PF guidelines and post your attempt.
Oh, and: does the rubber block stay in place or can it e.g. fly off because it's hanging from a wire ?
shin said:
Homework Statement:: A 7.80 g bullet is initially moving at 500 m/s just before it penetrates a block of solid rubber to a depth of 4.50 cm.
This is a distressingly frequent blunder by question setters who ought to know better.
Average force is ##F_{avg}=\frac{\Delta p}{\Delta t}##, the change in momentum divided by elapsed time. In vectors, ##\vec F_{avg}=\frac{\vec{\Delta p}}{\Delta t}##.
Note that this is consistent with acceleration and velocity. Cancelling mass out we get:
##a_{avg}=\frac{\Delta v}{\Delta t}##.
In general, this is not the same as ##\frac{\Delta E}{\Delta s}##, where E is energy and Δs is displacement in the direction of the force. They will be the same if the force is constant, but it cannot be written as a vector equation because energy is a scalar and you cannot divide by a vector.
Hence the correct wording of the question may be:
Assume the frictional force is constant during the penetration.
a) What is its magnitude?
b) How long does the penetration take?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
