Calculating Gas Pressure in a Piston System with Added Weight
In summary, the conversation discusses the pressure and volume of a gas inside a cylinder at room temperature. The first part focuses on finding the pressure of the gas when a block is added to the piston, while the second part uses the ideal gas law to find the volume. In the last two parts, the conversation considers what pressure is needed for a specific volume and how much mass must be added to the piston to achieve that pressure. The lack of information about the piston's area prevents a complete solution.
dragon162
Suppose the system is at room temperature, 300 kelvin, and that before we put weights on top of the plunger in the cylinder the pressure inside is 1 atmosphere.
1)If i place a .5kg block on top of the piston, what is the pressure of the gas inside the cylinder?
2)At that pressure what is the volume of the gas?
3)If i want to have L=0cm what should the pressure be?
4)how much mass would we have to pile on top of the piston to achieve that pressure inside the system?
PV=nRT
Volume of piston is V=L*A
Ok I am confused as how to find the pressure of the gas when the block is added to the piston. Since the block is on the piston doesn't it apply a pressure of mg, (.5kg)(9.8)=4.9?
The second part is obvious, just use PV=nRT but I have to find the pressure in part 1 first. As for the other two I don't know how to start them but I am focused on the first part right now.
bumpy bump help please
mg would be a force, not a pressure. The block applies a force of mg. To get the pressure, you would need to know the area of the piston's face. Without that information, the problem cannot be solved.
FAQ: Calculating Gas Pressure in a Piston System with Added Weight
What is the pressure of a gas in a piston?
The pressure of a gas in a piston is the force exerted by the gas on the walls of the piston. It is measured in units of pressure, such as pounds per square inch (psi) or pascals (Pa).
How is the pressure of a gas in a piston calculated?
The pressure of a gas in a piston can be calculated using the ideal gas law, which states that pressure is equal to the product of the gas's moles, temperature, and the ideal gas constant, divided by the volume of the piston.
What factors affect the pressure of a gas in a piston?
The pressure of a gas in a piston is affected by the amount of gas present, the temperature of the gas, and the volume of the piston. Changes in any of these factors can cause the pressure to increase or decrease.
How does the pressure of a gas in a piston change as the volume of the piston decreases?
As the volume of the piston decreases, the pressure of the gas inside increases. This is because the same amount of gas is now contained in a smaller space, causing the gas particles to collide with the walls of the piston more frequently and with greater force.
What happens to the pressure of a gas in a piston if the temperature is increased?
If the temperature of the gas in a piston is increased, the pressure will also increase. This is because an increase in temperature causes the gas particles to move faster and collide with the walls of the piston more frequently, resulting in an increase in pressure.
