A Calculating geodesic equation from Hamiltonian in presence of EM
Jokar
I have a Hamiltonian
H = \frac{1}{2} g^{\alpha \beta}\left(p_\alpha- A_\alpha\right)\left(p_\beta- A_\beta\right)
I want to calculate the equation of motion. How can I calculate the equation of motions
\frac{dx^\mu}{d\tau} = g^{\mu\nu}(p_\nu - A_\nu)
This one is straight forward. However, how can I calculate
\frac{dp^\mu}{d\tau} -\Gamma^\mu_{\alpha\beta}\frac{dx^\alpha}{d\tau}\frac{dx^\beta}{d\tau} = g^{\mu\nu} F_{\nu\beta} p^\beta
Can someone please help me with the derivation or give me some reference?
I never saw derivation of geodesic from Hamiltonian, but it seems to work indeed. Where did you find this?
Regarding how to proceed with the derivation. You already used the first equation, namely
$$\frac{dx^\alpha}{d\tau}=\frac{\partial H}{\partial p_\alpha}$$
Now use the second one
$$\frac{dp_\alpha}{d\tau}=-\frac{\partial H}{\partial x^\alpha}$$
Note that both ##g## and ##A## depend on ##x##, while ##p## doesn't.
Though the derivation actually splits into two separate parts - one for geodesic equation (no force) and other for the Lorentz force. And it's easier to do these parts individually, so I'd suggest to start without EM field, namely with ##H=\frac{1}{2}g^{\alpha\beta} p_\alpha p_\beta## (you should get the usual Euler-Lagrange equation for geodesic) and only than add the field.
I didn't go through the calculation to the very end myself, but I'm more or less confident I can do it. So feel free to ask if you have issues with particular steps.
Thanks. I am also doing the same thing. But I think there are some steps in between.
If you take the derivative then you will get
\frac{dp_\gamma}{d\tau} = -\frac{1}{2}
\frac{\partial {g^{\alpha\beta}}}{\partial x^\gamma}
(p_\alpha - A_\alpha)(p_\beta - A_\beta) + g^{\alpha\beta}(p_\alpha - A_\alpha)\frac{\partial A_\beta}{\partial x^\gamma}
What next? How can get the Christoffel symbol and the electromagnetic tensor. Am I doing anything wrong?
Any help?
You have two equations. Now you use the first one to eliminate ##p## from the second one. Note the convenient ##p_\mu-A_\mu## in the second one waiting to be replaced with the first one. Also when replacing ##p## on the left side, you'll peek up another derivative of the metric (it will go to the Christoffel symbol together with the one of the right) and a derivative of ##A## (it will make the EM tensor together with the other one). Collect few terms, do a bit of algebra and you are almost there.
Thanks. I did not replace it in the left side. So I was not getting the answer. Thank you very much.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
